Color information seem missed when opening step file in isaac sim but it is present when opened in omniverse kit
Hi guys
Could you share any idea how to get color information reflected in issaac sim after importing step file, please? it looks like all grey dim thing.
omniverse kit on the other hand shows colors correctly after import ;
Update:
after saving usd file from standalone omniverse kit latest release [ without launcher] the resulting usd file opens in isaac sim through launcher
but if I try to import directly to omniverse kit release from the launcher or to isaac sim release from the launcher it won’t show color
Update in 4.0.0 it works in 2023.1.1 it won’t as it turned out
Looks like problem is solved on latest release! but to double check, can you confirm to me the workflow you are using to import a step file? a simple gif would be very beneficial. The cad importer should handle materials since its first version so it’s surprising to me that it’s failing.
