Compatibility of Meta Quest 3 Touch Plus Controller with Omniverse
hello
I’m planning to buy a Meta Quest 3 Touch Plus controller and I want to know if it’s compatible with Omniverse. ((I can’t find it…😭
Also, could you please provide instructions on how to connect and set it up if it is compatible? Any relevant resources or documentation would be greatly appreciated !!!
Please see if Setting Up Meta Quest 3 with NVIDIA Omniverse | Learn With Me is helpful.
with Isaac Sim 4.x (inlcuding 4.2), the teleportation mechanic with the Quest 3 controller is jittery and half broken (using the joystick of the right controller to teleport inside the scene). But with 2023.1.1 it works as expected.
There is no easy way to disable the broken teleportation mechanic, and it takes over the joystick binding of the Quest controller, preventing it from being used for custom actions e.g. moving the robot.
The only workaround was to modify the source of meta quest extension to disable and free up all controller keybindings.
Otherwise the VR experience works nicely (Windows 11 + Meta Quest 3 with USB link). I was able to get 90hz stable FPS with the humanoid demo, Isaac 4.2 and RTX 4090.
