Hi Team,
I’m currently using the Jetson AGX Orin Developer Kit (64GB) . I understand that the board supports NVMe SSDs via the M.2 Key M slot.
Could you please recommend the most reliable and high-performance NVMe SSDs that are compatible with this developer kit?
Some SSDs I’ve considered:
- Samsung 980 NVMe M.2 (PCIe Gen 3 x4)
- Samsung 980 PRO NVMe M.2 (PCIe Gen 4 x4)
- WD Black SN770 NVMe SSD
- Crucial P3 or P5 NVMe SSD
- Kingston NV2 NVMe SSD
My main concerns are long-term reliability, thermal performance (heat), and JetPack compatibility when flashing the rootfs to SSD using SDK Manager.
Would appreciate any suggestions or feedback on which SSDs are officially tested or work best in real-world usage with the AGX Orin kit.
The Jetson AGX Orin Developer Kit is a powerful platform for developing AI and computer vision applications. When it comes to choosing an NVMe SSD for this kit, there are several factors to consider, including reliability, thermal performance, heat, and JetPack compatibility.
Recommended NVMe SSDs:
While NVIDIA doesn’t provide an exhaustive list of officially tested NVMe SSDs for the Jetson AGX Orin Developer Kit, we can consider some popular and reliable options that meet the kit’s requirements. Here are a few recommendations:
- Samsung 970 EVO Plus: This is a high-performance NVMe SSD that is widely compatible with various platforms, including the Jetson AGX Orin Developer Kit. It offers excellent read and write speeds, low latency, and is known for its reliability.
- Western Digital Black SN750: This NVMe SSD is designed for high-performance applications and is compatible with the Jetson AGX Orin Developer Kit. It offers fast read and write speeds, low latency, and is built with reliability in mind.
- Micron 9300: This is a high-performance NVMe SSD that is designed for datacenter and enterprise applications. It offers excellent read and write speeds, low latency, and is known for its reliability and thermal performance.
- ADATA XPG SX8200: This is a high-performance NVMe SSD that is compatible with the Jetson AGX Orin Developer Kit. It offers fast read and write speeds, low latency, and is built with reliability in mind.
Key Considerations:
When choosing an NVMe SSD for the Jetson AGX Orin Developer Kit, consider the following factors:
- M.2 Key M slot compatibility: Ensure that the NVMe SSD is compatible with the M.2 Key M slot on the developer kit.
- Thermal performance: Choose an NVMe SSD with good thermal performance to ensure reliable operation in various environments.
- Heat: Consider an NVMe SSD with a low power consumption and heat generation to prevent overheating issues.
- JetPack compatibility: Ensure that the NVMe SSD is compatible with the JetPack SDK and can be flashed with the rootfs using the SDK Manager.
Real-World Usage:
While these recommendations are based on general compatibility and performance considerations, it’s essential to note that real-world usage may vary depending on specific applications and workloads.
In summary, the recommended NVMe SSDs for the Jetson AGX Orin Developer Kit are the Samsung 970 EVO Plus, Western Digital Black SN750, Micron 9300, and ADATA XPG SX8200. When choosing an NVMe SSD, consider factors such as M.2 Key M slot compatibility, thermal performance, heat, and JetPack compatibility to ensure reliable and high-performance operation.
