The Jetson AGX Orin DevKit is a powerful platform, and choosing the right NVMe M2 SSD is crucial for optimal performance. I’ll provide you with a detailed analysis of the Samsung 990 EVO SSD and its suitability for the Jetson AGX Orin DevKit.
Thermal Performance:
The Samsung 990 EVO SSD is a PCIe Gen 4x4 and Gen 5x2 M2 2280 NVMe drive, which means it’s designed to handle high-speed data transfer rates. However, this also means it can generate more heat compared to slower drives.
According to Samsung’s specifications, the 990 EVO SSD has a maximum operating temperature of 85°C (185°F). While this is within the acceptable range for most systems, it’s essential to consider the Jetson AGX Orin DevKit’s thermal design and the SSD’s placement within the system.
Comparison with Samsung 970 EVO Plus:
The Samsung 970 EVO Plus SSD, which you mentioned had heat dissipation issues, is a PCIe Gen 3x4 M2 2280 NVMe drive. Although it’s an older model, it’s still a high-performance drive. The 970 EVO Plus has a maximum operating temperature of 70°C (158°F), which is lower than the 990 EVO’s maximum temperature.
Suitability for Jetson AGX Orin DevKit:
The Samsung 990 EVO SSD is a good choice for the Jetson AGX Orin DevKit, considering its high-performance capabilities and compatibility with the platform. However, to ensure optimal thermal performance and prevent overheating, you may need to consider additional thermal management measures.
Additional Thermal Management:
To mitigate potential thermal issues, you can consider the following:
- Heat sinks: Installing a heat sink specifically designed for M2 NVMe SSDs can help dissipate heat more efficiently. Make sure to choose a heat sink that is compatible with the Jetson AGX Orin DevKit’s M2 slot and the Samsung 990 EVO SSD.
- Thermal pads: Applying thermal pads between the SSD and the heat sink can improve heat transfer and reduce temperatures.
- Cooling systems: If you plan to use the Jetson AGX Orin DevKit in a demanding environment or with intense workloads, consider using a more comprehensive cooling system, such as a fan or a liquid cooling solution.
- Monitoring temperatures: Keep an eye on the SSD’s temperatures using software tools or the Jetson AGX Orin DevKit’s built-in temperature monitoring features. This will help you identify potential thermal issues before they become critical.
In summary, the Samsung 990 EVO SSD is a good choice for the Jetson AGX Orin DevKit, but it’s essential to consider additional thermal management measures to ensure optimal performance and prevent overheating. By taking these precautions, you can enjoy the high-performance capabilities of the 990 EVO SSD while maintaining a stable and reliable system.
