dimaz
May 12, 2022, 8:59am
1
Hi.
I cloned Release 34.1.
I want to download sources, so i run source_sync.sh script.
According to the official manual, release tag is jetson-r34.1.0 :
But software can’t find tag:
Couldn't find tag jetson-r34.1.0
/media/programmer/06f11819-bea4-4a65-a3b5-569303d4e4a6/work/orin/Linux_for_Tegra/sources/hardware/nvidia/soc/tegra source sync to tag jetson-r34.1.0 failed!
Another one issue:
Downloading default kernel/nvethernetrm source...
Cloning into '/media/programmer/06f11819-bea4-4a65-a3b5-569303d4e4a6/work/orin/Linux_for_Tegra/sources/kernel/nvethernetrm'...
fatal: Unable to look up nv-tegra.nvidia.com (port 9418) (Name or service not known)
/media/programmer/06f11819-bea4-4a65-a3b5-569303d4e4a6/work/orin/Linux_for_Tegra/sources/kernel/nvethernetrm source sync failed!
How to resolve it?
kayccc
May 12, 2022, 11:06pm
2
Hi dimaz ,
The right tag to use is “jetson-r34.1_dp”, it’s our typo, our document/web team are correcting the 34.1 release notes in Jetson Linux | NVIDIA Developer and Jetson Software Documentation pages.
dimaz
May 15, 2022, 7:33am
3
Hi kayccc .
Thank you, it works.
Next issue is related to the compilation process:
HOSTCC scripts/dtc/dtc-parser.tab.o
HOSTLD scripts/dtc/dtc
HOSTCC scripts/kallsyms
HOSTCC scripts/sorttable
DTC arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dtb
HOSTCC scripts/genksyms/genksyms.o
In file included from arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts:17:0:
arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/cvm/tegra234-p3701-0000.dtsi:19:10: fatal error: t234-common-cvm/tegra234-cvm-p3701.dtsi: No such file or directory
#include <t234-common-cvm/tegra234-cvm-p3701.dtsi>
compilation terminated.
arch/arm64/boot/dts/Makefile:79: recipe for target 'arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dtb' failed
make[1]: *** [arch/arm64/boot/dts/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/_ddot_/hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dtb] Error 1
Makefile:1389: recipe for target 'dtbs' failed
make: *** [dtbs] Error 2
make: *** Waiting for unfinished jobs....
How to resolve it?
If it’s still an issue, please help to open a new topic, let’s keep one issue one topic.
dimaz
May 26, 2022, 10:25am
5
I’ve found solution in this topic:
Dear NVidia Team
While trying to build the DTBS and the Kernel for JetPack 5.0 DP, we stumbled across two errors.
make dtbs fails with the error below. As we are building the device-tree for AGX Xavier, we commented out the builds for the Orin as a workaround.
We try to build the kernel with the following steps:
a. export ARCH=arm64
b. export CROSS_COMPILE=/home/netipc/nvidia/nvidia_sdk/toolchain/l4t-gcc/bi…
dimaz
June 5, 2022, 2:17pm
6
In Release 34.1.1 there is error too.
According to the documentation tag is jetson-r34.1.1
But actual tag is jetson_34.1.1
It is strange that such errors are exist in official document.
