Hello everyone. I am trying to build a package from an example matlab: Deep Learning with MATLAB, NVIDIA Jetson, and ROS Video - MATLAB. However, I get a strange error when using catkin_make : nvcc fatal : Don’t know what to do with ‘/usr/lib/x86_64-linux-gnu/libconsole_bridge.so.0.4’ . I get the same error on jetson nano. Please tell me where the possible source of the problem is.
I have the same problem, is there any solution to it? can anyone provide a working cmake file
hello, what do you use? PC or jetson?
ср, 19 янв. 2022 г. в 19:12, Sandro Steinhuber via NVIDIA Developer Forums <nvidia@discoursemail.com>:
Is there any solution to this problem? I also ran into the same issue, while trying to run it from jetson
Hello, I managed to run this package for a long time, I’m sorry that I didn’t answer for a long time, I had this package on Jetson, but it failed, but I found CmakeList.txt for PC. i can send you the CmakeList, may be it help
сб, 2 апр. 2022 г. в 08:34, user128851 via NVIDIA Developer Forums <nvidia@discoursemail.com>:
