Compiling libgstnvvideosinks.so failed
I downloaded 32.5.1 L4T Driver Package (BSP) Sources and trying to compile libgstnvvideosinks.so
The build failed with belowing failing message:
Makefile:69: ../../../deepstream/sdk/Rules.mk: No such file or directory
make: *** No rule to make target ‘../../../deepstream/sdk/Rules.mk’. Stop.
I have downloaded deepstream-5.1_5.1.0-1_arm64.deb and installed but couldn’t find “deepstream/sdk/Rules.mk”
The Makefile is as following:
Copyright (c) 2019-2020, NVIDIA CORPORATION. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA Corporation is strictly prohibited.
CC:= gcc
TARGET_NAME := libgstnvvideosinks.so
SRCS := common/context.c \
common/display.c \
common/egl/context_egl.c \
common/renderer.c \
common/renderer/renderer_gl.c \
common/window.c \
common/x11/display_x11.c \
common/x11/window_x11.c \
gstnvvideosinks.c \
nv3dsink/gstnv3dsink.c
IS_GST_PLUGIN:=1
CFLAGS := -fPIC \
-DNV_VIDEO_SINKS_HAS_EGL \
-DNV_VIDEO_SINKS_HAS_GL \
-DNV_VIDEO_SINKS_HAS_NV3DSINK \
-DNV_VIDEO_SINKS_HAS_X11 \
-DIS_DESKTOP
NEEDS_CUDA:=1
IGNORE_DS_PACKAGE_NAMING:=1
PACKAGE_BINARY_IN_DS:=1
LDFLAGS:= -shared
CAN_PUBLIC_LINK:=1
INC_PATHS =: \
common \
common/egl \
common/renderer \
common/x11 \
/usr/local/include/gstreamer-1.0 \
../../../3rdparty/gst/gst-nveglglessink/gst-libs/ \
../../../nvutils/nvbufsurface/ \
PKGS := glib-2.0 \
gstreamer-1.0 \
gstreamer-base-1.0 \
gstreamer-video-1.0
CFLAGS += pkg-config --cflags $(PKGS)
LDFLAGS = -Wl,–no-undefined -L/usr/lib/aarch64-linux-gnu/tegra
LIBS = -lnvbufsurface -lGLESv2 -lEGL -lX11 -lm -lcuda -lcudart
LIBS += pkg-config --libs $(PKGS)
include ../../../deepstream/sdk/Rules.mk
We can reproduce the issue. Thanks for reporting it.
Will update once there is progress.
Hi, Any progress about this topic ? Thanks.
The issue is still present in Jetpack 4.6. It is under investigation.
This is fixed in Jetpack 4.6.1
