Hello everyone!
At the beginning I have to say that I’m beginner both in Linux and Jetson. I have some problems with installing Jetpack 4.3 on Jetson TX1 using SDKManager 1.0.1.5538
Software used:
Host - Ubuntu 18.04 (not VM)
Jetson - Ubuntu 16.04
I must say that I received Jetson with whole Developer Kit from university with previously installed Ubuntu and now I would like to install the latest Jetpack on it. Everything seems perfect up to the moment when SDKManager tries to connect via USB cable with Jetson. Jetson is running and opened on desktop. I try to connect with IP Address: 192.168.55.1
On host there is a statement:
Could not detect Nvidia Jetson device connected to USB. Verify that:
- is connected to this host machine with a USB cable.
- Jetson’s Ubuntu OS is up and running.
- Ubuntu ‘System configuration wizard’ is completed on the device.
This can be validated by running the ‘lsusb’ command on your host, and look for “0955:7721” (NVIDIA Corp).
17:48:13 DEBUG : running command < [ lsusb | grep -c "0955:" -ne 1 ] >
17:48:13 INFO : command finished successfully
17:48:13 DEBUG : running command < [ lsusb | grep -c "0955:" -gt 1 ] >
17:48:13 DEBUG : command terminated with error
17:48:13 ERROR : Could not detect Nvidia Jetson device connected to USB. Verify that: 1. is connected to this host machine with a USB cable. 2. Jetson’s Ubuntu OS is up and running. 3. Ubuntu ‘System configuration wizard’ is completed on the device. This can be validated by running the ‘lsusb’ command on your host, and look for “0955:7721” (NVIDIA Corp). Or use the ‘Manual Setup’ instead.
When I use eth0 as an IP Address it says:
Cannot connect to the device via SSH. Validate that SSH serivce is running on the device or use the ‘Manual Setup’ instead.
18:17:03 DEBUG : running command < nc -z -vv -w 5 eth0 22 >
18:17:03 INFO : nc: getaddrinfo for host “eth0” port 22: Name or service not known
18:17:03 DEBUG : command terminated with error
18:17:03 ERROR : Cannot connect to the device via SSH. Validate that SSH serivce is running on the device or use the ‘Manual Setup’ instead.
18:17:14 DEBUG : running command < nc -z -vv -w 5 eth0 22 >
18:17:14 INFO : nc: getaddrinfo for host “eth0” port 22: Name or service not known
18:17:14 DEBUG : command terminated with error
18:17:14 ERROR : Cannot connect to the device via SSH. Validate that SSH serivce is running on the device or use the ‘Manual Setup’ instead.
Command lsusb cannot find my Jetson. Is it even possible to install components on Jetson without flashing new OS?
Thank you in advance for your help.
