computeprof.app do not run the application ... (problem loading the dynamic library)
Hi all,
I’m running CUDA 3.1 on MAcOS 10.6.4 on a powerbook pro (GeForce 9400M)
I correctly run my application, but when I run compiteprof.app
(nvidia compute visual profiler version 3.1.1) on the same application,
with the same command line parameters i get the following errors
(problem with dynamic library loading): did I miss some configurations?
thanks
giammy
=== Start profiling for session ‘Session1’ ===
Start program ‘/Users/giammy/Desktop/Dropbox/data-rem1/src/cnc-gpu-cuda-0.9-2/CG-GPU/cg-gpu’ run #1
dyld: Library not loaded: @rpath/libcudart.dylib
Referenced from: /Users/giammy/Desktop/Dropbox/data-rem1/src/cnc-gpu-cuda-0.9-2/CG-GPU/cg-gpu
Reason: image not found
Program run #1 completed.
Start program ‘/Users/giammy/Desktop/Dropbox/data-rem1/src/cnc-gpu-cuda-0.9-2/CG-GPU/cg-gpu’ run #2
/libcudart.dylib
Program run #2 completed.
Start program ‘/Users/giammy/Desktop/Dropbox/data-rem1/src/cnc-gpu-cuda-0.9-2/CG-GPU/cg-gpu’ run #3
Program run #3 completed.
Start program ‘/Users/giammy/Desktop/Dropbox/data-rem1/src/cnc-gpu-cuda-0.9-2/CG-GPU/cg-gpu’ run #4
/libcudart.dylib
Referenced fr
-2/CG-GPU/cg-gpu
Reason: image
not found
Program run #4 completed.
Error in reading profiler output.
Hi all,
this problem is resolved: running the computeprof application from GUI
apparently do not set the DYLD_LIBRARY_PATH variable.
Running it from command line fix the problems … is it an application
or configuration bug?
Anyway, another problem is that, after compiling the SDK examples, i’m
testing matrixmul, it runs correctly, but computeprof get no data:
Start program ‘/Developer/GPU Computing/C/bin/darwin/release/matrixMul’ run #1
[ matrixMul ]
/Developer/GPU Computing/C/bin/darwin/release/matrixMul Starting…
Device 0: “GeForce 9400M” with Compute 1.1 capability
Using Matrix Sizes: A(32 x 64), B(32 x 64), C(32 x 64)
Start program ‘/Developer/GPU Computing/C/bin/darwin/release/matrixMul’ run #2
[ matrixMul ]
Run Kernels…
matrixMul, Throughput = 0.8933 GFlop/s, Time = 0.00015 s, Size = 131072 Ops, NumDevsUsed = 1, Workgroup = 256
Check against Host computation…
PASSED
/Developer/GPU Computing/C/bin/darwin/release/matrixMul Exiting…
Start program ‘/Developer/GPU Computing/C/bin/darwin/release/matrixMul’ run #3
[ matrixMul ]
Run Kernels…
matrixMul, Throughput = 0.9487 GFlop/s, Time = 0.00014 s, Size = 131072 Ops, NumDevsUsed = 1, Workgroup = 256
PASSED
Start program ‘/Developer/GPU Computing/C/bin/darwin/release/matrixMul’ run #4
[ matrixMul ]
Run Kernels…
matrixMul, Throughput = 0.9659 GFlop/s, Time = 0.00014 s, Size = 131072 Ops, NumDevsUsed = 1, Workgroup = 256
PASSED
There is some error in profiling. The profiler output file is empty.
any idea?
thanks
giammy
another update: running the program with the triangle icon on the gui give
the error result i posted in the last reply, but if I open
Session → Session Settings and I push the start button in this window,
the program runs correctly and the profiling is working correctly!
Again: anyone has these problems? is it a my misconfiguration?
thanks
giammy
