14:07:29 INFO: OpenCV Runtime - target: python-pyparsing python-scandir python-six python-wcwidth python-zipp
14:07:29 INFO: OpenCV Runtime - target: python2-dev python2.7-dev
14:07:29 INFO: OpenCV Runtime - target: Suggested packages:
14:07:29 INFO: OpenCV Runtime - target: apache2 | lighttpd | httpd python-attr-doc python-funcsigs-doc
14:07:29 INFO: OpenCV Runtime - target: python-numpy-dbg python-numpy-doc python-setuptools subversion
14:07:29 INFO: OpenCV Runtime - target: python-pyparsing-doc python-mock
14:07:30 INFO: OpenCV Runtime - target: The following packages will be REMOVED:
14:07:30 INFO: OpenCV Runtime - target: python-is-python3
14:07:30 INFO: OpenCV Runtime - target: The following NEW packages will be installed:
14:07:30 INFO: OpenCV Runtime - target: javascript-common libexpat1-dev libjs-sphinxdoc libjs-underscore
14:07:30 INFO: OpenCV Runtime - target: libpython2-dev libpython2.7-dev python-atomicwrites python-attr
14:07:30 INFO: OpenCV Runtime - target: python-configparser python-contextlib2 python-dev-is-python2 python-funcsigs
14:07:30 INFO: OpenCV Runtime - target: python-importlib-metadata python-is-python2 python-more-itertools
14:07:30 INFO: OpenCV Runtime - target: python-numpy python-packaging python-pathlib2 python-pkg-resources
14:07:30 INFO: OpenCV Runtime - target: python-pluggy python-py python-pyparsing python-pytest python-scandir
14:07:30 INFO: OpenCV Runtime - target: python-six python-wcwidth python-zipp python2-dev python2.7-dev
14:07:30 INFO: OpenCV Runtime - target: 0 upgraded, 29 newly installed, 1 to remove and 223 not upgraded.
14:07:30 INFO: OpenCV Runtime - target: Need to get 5,714 kB of archives.
14:07:30 INFO: OpenCV Runtime - target: After this operation, 29.6 MB of additional disk space will be used.
14:08:00 ERROR: OpenCV Runtime - target: 0% [Working] 0% [Connecting to ports.ubuntu.com (185.125.190.39)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] Err:1 Index of /ubuntu-ports focal/main arm64 javascript-common all 11
14:08:00 INFO: OpenCV Runtime - target: Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::19). - connect (101: Network is unreachable) Cannot initiate the connection to ports.ubuntu.com:80 (2620:2d:4000:1::16). - connect (101: Network is unreachable) Could not connect to ports.ubuntu.com:80 (185.125.190.36), connection timed out Could not connect to ports.ubuntu.com:80 (185.125.190.39), connection timed out
14:08:00 INFO: OpenCV Runtime - target: 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] Ign:2 Index of /ubuntu-ports focal-updates/main arm64 libexpat1-dev arm64 2.2.9-1ubuntu0.6
14:08:00 INFO: OpenCV Runtime - target: Ign:3 Index of /ubuntu-ports focal-updates/main arm64 libjs-underscore all 1.9.1~dfsg-1ubuntu0.20.04.1
14:08:00 ERROR: OpenCV Runtime - target: 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] Err:4 Index of /ubuntu-ports focal/main arm64 libjs-sphinxdoc all 1.8.5-7ubuntu3
14:08:00 INFO: OpenCV Runtime - target: Ign:5 Index of /ubuntu-ports focal-updates/universe arm64 libpython2.7-dev arm64 2.7.18-1~20.04.3
14:08:00 ERROR: OpenCV Runtime - target: Err:6 Index of /ubuntu-ports focal/universe arm64 libpython2-dev arm64 2.7.17-2ubuntu4
14:08:00 ERROR: OpenCV Runtime - target: 0% [Working] Err:7 Index of /ubuntu-ports focal/universe arm64 python-atomicwrites all 1.1.5-2build1
14:08:00 ERROR: OpenCV Runtime - target: Err:8 Index of /ubuntu-ports focal/universe arm64 python-attr all 19.3.0-2
14:08:00 ERROR: OpenCV Runtime - target: 0% [Working] Err:9 Index of /ubuntu-ports focal/universe arm64 python-configparser all 3.5.0b2-3build1
14:08:00 ERROR: OpenCV Runtime - target: 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] Err:10 Index of /ubuntu-ports focal/universe arm64 python-contextlib2 all 0.6.0-2
14:08:00 ERROR: OpenCV Runtime - target: 0% [Working] Err:11 Index of /ubuntu-ports focal/universe arm64 python-is-python2 all 2.7.17-4
14:08:00 INFO: OpenCV Runtime - target: 0% [Working] Ign:12 Index of /ubuntu-ports focal-updates/universe arm64 python2.7-dev arm64 2.7.18-1~20.04.3
14:08:00 ERROR: OpenCV Runtime - target: Err:13 Index of /ubuntu-ports focal/universe arm64 python2-dev arm64 2.7.17-2ubuntu4
14:08:00 ERROR: OpenCV Runtime - target: 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::16)] Err:14 Index of /ubuntu-ports focal/universe arm64 python-dev-is-python2 all 2.7.17-4
14:08:00 ERROR: OpenCV Runtime - target: Err:15 Index of /ubuntu-ports focal/universe arm64 python-funcsigs all 1.0.2-4build1
14:08:00 ERROR: OpenCV Runtime - target: Err:16 Index of /ubuntu-ports focal/universe arm64 python-six all 1.14.0-2
14:08:00 ERROR: OpenCV Runtime - target: 0% [Connecting to ports.ubuntu.com (2620:2d:4000:1::19)] Err:17 Index of /ubuntu-ports focal/universe arm64 python-scandir arm64 1.10.0-2ubuntu3
14:08:00 ERROR: OpenCV Runtime - target: Err:18 Index of /ubuntu-ports focal/universe arm64 python-pathlib2 all 2.3.5-1ubuntu1
INSTALLATION FAILED
Please review the terminal tab for details. Resolve and RETRY.
Flash of target hardware was skipped.
EXPORT LOGS
RETRY
FAILED ITEMS
STOP TRYING
Copyright Ā© 2023, NVIDIA CORPORATION. All rights reserved. | NVIDIA Developer
