Platform: Jetson AGX Xavier, **
Linux version: 20.04, R35.2,
** Audio codec: WM8904,
I2C Address:0x1a
➜ ~ sudo i2cdetect -y -r -a 7
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- --
The addresses corresponding to I2C are as follows
➜ ~ sudo i2cdetect -l
i2c-3 i2c 3190000.i2c I2C adapter
i2c-1 i2c c240000.i2c I2C adapter
i2c-101 i2c 15210000.display I2C adapter
i2c-8 i2c 31e0000.i2c I2C adapter
i2c-6 i2c 31c0000.i2c I2C adapter
i2c-4 i2c Tegra BPMP I2C adapter I2C adapter
i2c-2 i2c 3180000.i2c I2C adapter
i2c-0 i2c 3160000.i2c I2C adapter
i2c-102 i2c 15220000.display I2C adapter
i2c-7 i2c c250000.i2c I2C adapter
i2c-5 i2c 31b0000.i2c I2C adapter
Below is the required kernel device tree information
i2c@c250000 {
//add
wm8904_codec: wm8904@1a {
compatible = "wlf,wm8904";
status ="okay";
reg = <0x1a>;
// clocks = <&wm8904_mclk>;
// clocks = <&bpmp TEGRA194_CLK_AUD_MCLK>;
clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
// clocks = <&pck0>;
clock-names = "mclk";
port {
wm8904_ep: endpoint {
remote-endpoint = <&i2s1_dap_ep>;
mclk-fs = <256>;
link-name = "wm8904-playback";
/* Default for all I2S is long fsync width(31) */
aconnect@2a41000 {
compatible = "nvidia,tegra210-aconnect";
status = "okay";
ahub {
/* I2S4 in Short frame sync for BT SCO */
i2s@2901300 {
bclk-ratio = <4>;
status = "okay";
tegra_acsl_audio: acsl_audio {
status = "okay";
hda@3510000 {
status = "okay";
nvidia,model = "NVIDIA Jetson AGX Xavier HDA";
tegra_sound: sound {
status = "okay";
compatible = "nvidia,tegra186-ape";
nvidia-audio-card,name = "NVIDIA Jetson AGX Xavier APE";
nvidia,num-codec-link = <1>;
nvidia,num-clk = <6>;
nvidia,clk-rates = < 270950400 /* PLLA_x11025_RATE */
11289600 /* AUD_MCLK_x11025_RATE */
45158400 /* PLLA_OUT0_x11025_RATE */
45158400 /* AHUB_x11025_RATE */
245760000 /* PLLA_x8000_RATE */
12288000 /* AUD_MCLK_x8000_RATE */
49152000 /* PLLA_OUT0_x8000_RATE */
49152000 >;/* AHUB_x8000_RATE */
nvidia,xbar = <&tegra_axbar>;
clocks = <&bpmp_clks TEGRA194_CLK_PLLA>,
<&bpmp_clks TEGRA194_CLK_PLLA_OUT0>,
clock-names = "pll_a", "pll_a_out0", "extern1";
assigned-clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>;
nvidia-audio-card,widgets =
"Headphone", "WM Headphone Jack",
"Microphone", "WM Mic",
"Line", "WM Line In Jack",
"Microphone", "WM MICBIAS";
//add
nvidia-audio-card,routing =
"WM Headphone", "WM HP_L",
"WM Headphone", "WM HP_R"
"WM Headphone Jack", "WM HPOUTL",
"WM Headphone Jack", "WM HPOUTR",
"WM IN2L", "WM Line In Jack",
"WM IN2R", "WM Line In Jack",
"WM Mic", "WM MICBIAS",
"WM IN1L", "WM Mic",
"WM Headphone", "WM HPOUTL",
"WM Headphone", "WM HPOUTR";
nvidia,dai-link-1 {
cpu-dai = <&tegra_i2s1>;
codec-dai = <&wm8904_codec>;
cpu-dai-name = "I2S1";
codec-dai-name = "wm8904-hifi";
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <0>;
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "WM";
status = "okay";
nvidia-audio-card,mclk-fs = <256>;
tegra_sound_graph: sound_graph {
compatible = "nvidia,tegra186-audio-graph-card";
* Tegra audio graph card is based on uptream generic audio
* graph sound card. In future there is plan to use this
* as default sound card.
status = "disabled";
dais = /* ADMAIF (FE) Ports */
<&admaif1_port>, <&admaif2_port>, <&admaif3_port>,
<&admaif4_port>, <&admaif5_port>, <&admaif6_port>,
<&admaif7_port>, <&admaif8_port>, <&admaif9_port>,
<&admaif10_port>, <&admaif11_port>, <&admaif12_port>,
<&admaif13_port>, <&admaif14_port>, <&admaif15_port>,
<&admaif16_port>, <&admaif17_port>, <&admaif18_port>,
<&admaif19_port>, <&admaif20_port>,
/* ADSP (FE) Ports */
<&adsp_pcm1_port>, <&adsp_pcm2_port>,
<&adsp_compr1_port>, <&adsp_compr2_port>,
/* XBAR I/O ports */
<&xbar_i2s1_port>, <&xbar_i2s2_port>, <&xbar_i2s3_port>,
<&xbar_i2s4_port>, <&xbar_i2s5_port>, <&xbar_i2s6_port>,
<&xbar_dmic1_port>, <&xbar_dmic2_port>,
<&xbar_dmic3_port>, <&xbar_dmic4_port>,
<&xbar_dspk1_port>, <&xbar_dspk2_port>,
/* XBAR HW accelerator ports */
<&xbar_sfc1_in_port>, <&xbar_sfc2_in_port>,
<&xbar_sfc3_in_port>, <&xbar_sfc4_in_port>,
<&xbar_mvc1_in_port>, <&xbar_mvc2_in_port>,
<&xbar_afc1_in_port>, <&xbar_afc2_in_port>,
<&xbar_afc3_in_port>, <&xbar_afc4_in_port>,
<&xbar_afc5_in_port>, <&xbar_afc6_in_port>,
<&xbar_asrc_in1_port>, <&xbar_asrc_in2_port>,
<&xbar_asrc_in3_port>, <&xbar_asrc_in4_port>,
<&xbar_asrc_in5_port>, <&xbar_asrc_in6_port>,
<&xbar_asrc_in7_port>, <&xbar_arad_port>,
<&xbar_mixer_in1_port>, <&xbar_mixer_in2_port>,
<&xbar_mixer_in3_port>, <&xbar_mixer_in4_port>,
<&xbar_mixer_in5_port>, <&xbar_mixer_in6_port>,
<&xbar_mixer_in7_port>, <&xbar_mixer_in8_port>,
<&xbar_mixer_in9_port>, <&xbar_mixer_in10_port>,
<&xbar_ope1_in_port>,
<&xbar_amx1_in1_port>, <&xbar_amx1_in2_port>,
<&xbar_amx1_in3_port>, <&xbar_amx1_in4_port>,
<&xbar_amx2_in1_port>, <&xbar_amx2_in2_port>,
<&xbar_amx2_in3_port>, <&xbar_amx2_in4_port>,
<&xbar_amx3_in1_port>, <&xbar_amx3_in2_port>,
<&xbar_amx3_in3_port>, <&xbar_amx3_in4_port>,
<&xbar_amx4_in1_port>, <&xbar_amx4_in2_port>,
<&xbar_amx4_in3_port>, <&xbar_amx4_in4_port>,
<&xbar_adx1_in_port>, <&xbar_adx2_in_port>,
<&xbar_adx3_in_port>, <&xbar_adx4_in_port>,
/* BE I/O Ports */
<&i2s1_port>, <&i2s2_port>, <&i2s3_port>,
<&i2s4_port>, <&i2s5_port>, <&i2s6_port>,
<&dmic1_port>, <&dmic2_port>, <&dmic3_port>,
<&dmic4_port>,
<&dspk1_port>, <&dspk2_port>,
/* BE HW accelerator ports */
<&sfc1_out_port>, <&sfc2_out_port>,
<&sfc3_out_port>, <&sfc4_out_port>,
<&mvc1_out_port>, <&mvc2_out_port>,
<&afc1_out_port>, <&afc2_out_port>,
<&afc3_out_port>, <&afc4_out_port>,
<&afc5_out_port>, <&afc6_out_port>,
<&asrc_out1_port>, <&asrc_out2_port>,
<&asrc_out3_port>, <&asrc_out4_port>,
<&asrc_out5_port>, <&asrc_out6_port>,
<&mixer_out1_port>, <&mixer_out2_port>,
<&mixer_out3_port>, <&mixer_out4_port>,
<&mixer_out5_port>,
<&ope1_out_port>,
<&amx1_out_port>, <&amx2_out_port>,
<&amx3_out_port>, <&amx4_out_port>,
<&adx1_out1_port>, <&adx1_out2_port>,
<&adx1_out3_port>, <&adx1_out4_port>,
<&adx2_out1_port>, <&adx2_out2_port>,
<&adx2_out3_port>, <&adx2_out4_port>,
<&adx3_out1_port>, <&adx3_out2_port>,
<&adx3_out3_port>, <&adx3_out4_port>,
<&adx4_out1_port>, <&adx4_out2_port>,
<&adx4_out3_port>, <&adx4_out4_port>,
/* ADSP related ports */
<&adsp_admaif1_port>, <&adsp_admaif2_port>,
<&adsp_admaif3_port>, <&adsp_admaif4_port>,
<&adsp_admaif5_port>, <&adsp_admaif6_port>,
<&adsp_admaif7_port>, <&adsp_admaif8_port>,
<&adsp_admaif9_port>, <&adsp_admaif10_port>,
<&adsp_admaif11_port>, <&adsp_admaif12_port>,
<&adsp_admaif13_port>, <&adsp_admaif14_port>,
<&adsp_admaif15_port>, <&adsp_admaif16_port>,
<&adsp_admaif17_port>, <&adsp_admaif18_port>,
<&adsp_admaif19_port>, <&adsp_admaif20_port>,
<&admaif1_codec_port>, <&admaif2_codec_port>,
<&admaif3_codec_port>, <&admaif4_codec_port>,
<&admaif5_codec_port>, <&admaif6_codec_port>,
<&admaif7_codec_port>, <&admaif8_codec_port>,
<&admaif9_codec_port>, <&admaif10_codec_port>,
<&admaif11_codec_port>, <&admaif12_codec_port>,
<&admaif13_codec_port>, <&admaif14_codec_port>,
<&admaif15_codec_port>, <&admaif16_codec_port>,
<&admaif17_codec_port>, <&admaif18_codec_port>,
<&admaif19_codec_port>, <&admaif20_codec_port>;
label = "NVIDIA Jetson AGX Xavier APE";
clock-names = "pll_a", "plla_out0";
widgets = "Headphone", "WM Headphone Jack",
routing = "WM Headphone Jack", "WM HPOUTL",
"WM IN1L", "WM Mic";
* For codec2codec based DAI link design this is required.
* For DPCM based design, this is optional and instead
* it will be picked from codec port node.
mclk-fs = <256>;
* Default config for all I2S dai links are
* format = "i2s", bitclock-slave, frame-slave,
* bitclock-noninversion, frame-noninversion,
* Any change from default needs override on
* platform specific files.
/* Override with Codec entries */
&i2s1_to_codec {
// link-name = "rt5658-playback";
bitclock-master;
frame-master;
codec {
sound-dai = <&wm8904_codec 0>;
prefix = "WM";
hdr40_snd_link_i2s: &i2s2_to_codec { };
/* Override with BT SCO entries */
&i2s4_to_codec {
format = "dsp_a";
bitclock-inversion;
/* Audio graph related bindings */
&i2s1_dap_ep {
remote-endpoint = <&wm8904_ep>;
&i2s4_dap_ep {
dai-format = "dsp_a";
bitclock-inversion;
hdr40_snd_i2s_dap_ep: &i2s2_dap_ep { };
The kernel configuration kconfig was modified to
config SND_SOC_WM8904
bool "Wolfson Microelectronics WM8904 CODEC"
default y
depends on I2C
the original
tristate "Wolfson Microelectronics WM8904 CODEC"
depends on I2C
After I compiled and updated to the board, I did not find the NVIDIA Jetson AGX Xavier APE
corresponding configuration
status = "okay";
There is no NVIDIA Jetson AGX Xavier APE corresponding to the sound card, which step is wrong? This question has been bothering me for a week now, hope for help
