Update:
I have removed the BCMDHD lines from the kernel config file, but the result is the same.
Things that might be interesting from the below pasted log:
- The Jetson tries to scan at multiple frequencies
- Interrupt are thrown for an unknown reason
- I think the error -19 came only after setting the regulator (
tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 1.8v) but would have to double check
- I get an error
mmc1: req done (CMD52): -110:
root@poc01:/home/dev# [ 3223.821469] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 3223.827915] sdhci: Sys addr: 0x00000000 | Version: 0x00000404
[ 3223.833842] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 3223.839706] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 3223.845549] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000000
[ 3223.851477] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 3223.857323] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 3223.863164] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 3223.869012] sdhci: Int enab: 0x00ff1003 | Sig enab: 0x00fc1003
[ 3223.874853] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 3223.880693] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18006f73
[ 3223.886533] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 3223.892368] sdhci: Host ctl2: 0x00003000
[ 3223.896315] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 3223.903068] sdhci: ===========================================
[ 3223.953646] sdhci-tegra 3440000.sdhci: Failed to create debugfs
^C
root@poc01:/home/dev# dmesg | tail -n 300
[ 3224.018577] sdhci-tegra 3440000.sdhci: Setting clk limit 200000
[ 3224.018584] sdhci-tegra 3440000.sdhci: Enabling clk 200000, clk enabled 1
[ 3224.018594] sdhci-tegra 3440000.sdhci: chosen clk parent pll_p, parent rate 408000000
[ 3224.018778] sdhci-tegra 3440000.sdhci: req clk 200000, set clk 3175098
[ 3224.020912] sdhci-tegra 3440000.sdhci: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 1.8v
[ 3224.021960] sdhci-tegra 3440000.sdhci: Initial signal voltage of 1.8v
[ 3224.041644] mmc1: clock 200000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 1 timing 0
[ 3224.061706] mmc1: starting CMD52 arg 00000c00 flags 00000195
[ 3224.062392] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.062481] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 3224.062507] mmc1: starting CMD52 arg 80000c08 flags 00000195
[ 3224.063186] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.063265] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 3224.063290] mmc1: clock 200000Hz busmode 2 powermode 2 cs 1 Vdd 7 width 1 timing 0
[ 3224.064357] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 3224.064685] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
[ 3224.064710] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 3224.065733] mmc1: clock 200000Hz busmode 2 powermode 2 cs 0 Vdd 7 width 1 timing 0
[ 3224.066803] mmc1: starting CMD5 arg 00000000 flags 000002e1
[ 3224.067469] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.067545] mmc1: req failed (CMD5): -110, retrying...
[ 3224.068205] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.068283] mmc1: req failed (CMD5): -110, retrying...
[ 3224.068944] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.069015] mmc1: req failed (CMD5): -110, retrying...
[ 3224.069684] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.069761] mmc1: req done (CMD5): -110: 00000000 00000000 00000000 00000000
[ 3224.069787] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 3224.070938] mmc1: mmc_rescan_try_freq: trying to init card at 101661 Hz
[ 3224.070946] mmc1: clock 101661Hz busmode 2 powermode 1 cs 0 Vdd 7 width 1 timing 0
[ 3224.070957] sdhci-tegra 3440000.sdhci: Setting clk limit 101661
[ 3224.070965] sdhci-tegra 3440000.sdhci: Enabling clk 101661, clk enabled 1
[ 3224.070976] sdhci-tegra 3440000.sdhci: chosen clk parent pll_p, parent rate 408000000
[ 3224.071249] sdhci-tegra 3440000.sdhci: req clk 101661, set clk 3175098
[ 3224.073381] sdhci-tegra 3440000.sdhci: tegra_sdhci_signal_voltage_switch_post: error -19 in comp drvup settings at 1.8v
[ 3224.074428] sdhci-tegra 3440000.sdhci: Initial signal voltage of 1.8v
[ 3224.093624] mmc1: clock 101661Hz busmode 2 powermode 2 cs 0 Vdd 7 width 1 timing 0
[ 3224.113707] mmc1: starting CMD52 arg 00000c00 flags 00000195
[ 3224.115034] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.115179] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 3224.115224] mmc1: starting CMD52 arg 80000c08 flags 00000195
[ 3224.116540] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.116669] mmc1: req done (CMD52): -110: 00000000 00000000 00000000 00000000
[ 3224.116710] mmc1: clock 101661Hz busmode 2 powermode 2 cs 1 Vdd 7 width 1 timing 0
[ 3224.120482] mmc1: starting CMD0 arg 00000000 flags 000000c0
[ 3224.121113] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00000001
[ 3224.121149] mmc1: req done (CMD0): 0: 00000000 00000000 00000000 00000000
[ 3224.122194] mmc1: clock 101661Hz busmode 2 powermode 2 cs 0 Vdd 7 width 1 timing 0
[ 3224.123275] mmc1: starting CMD5 arg 00000000 flags 000002e1
[ 3224.124594] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.124735] mmc1: req failed (CMD5): -110, retrying...
[ 3224.126049] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.126209] mmc1: req failed (CMD5): -110, retrying...
[ 3224.127516] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.127657] mmc1: req failed (CMD5): -110, retrying...
[ 3224.128965] sdhci [sdhci_irq()]: *** mmc1 got interrupt: 0x00018001
[ 3224.129095] mmc1: req done (CMD5): -110: 00000000 00000000 00000000 00000000
[ 3224.129135] mmc1: clock 0Hz busmode 2 powermode 0 cs 0 Vdd 0 width 1 timing 0
[ 3224.914431] sdhci-tegra 3460000.sdhci: Setting clk limit 196249804
[ 3224.914453] sdhci-tegra 3460000.sdhci: Enabling clk 200000000, clk enabled 0
[ 3224.914851] sdhci-tegra 3460000.sdhci: req clk 196249804, set clk 196249804
[ 3224.914892] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e3e17c80 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00001010 dir(r-1/w-0): 0
[ 3224.914911] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.914940] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x1010, intr: 1
[ 3224.914973] cmdq_prep_tran_desc: req: 0xffffffc0e3e17c80 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.915014] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e3e16480 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00401060 dir(r-1/w-0): 0
[ 3224.915030] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915051] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x401060, intr: 1
[ 3224.915069] cmdq_prep_tran_desc: req: 0xffffffc0e3e16480 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.915100] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2208f0 req: 0xffffffc0e3e16600 mqrq: 0xffffffc0eb2206f0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2208e8 card-addr: 0x00401120 dir(r-1/w-0): 0
[ 3224.915114] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915134] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x401120, intr: 1
[ 3224.915152] cmdq_prep_tran_desc: req: 0xffffffc0e3e16600 tag: 2 calc-link_desc: 0xffffff800a8b2000, sg-cnt: 1
[ 3224.915181] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220c68 req: 0xffffffc0e3e16000 mqrq: 0xffffffc0eb220a68 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220c60 card-addr: 0x00401130 dir(r-1/w-0): 0
[ 3224.915195] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915214] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x401130, intr: 1
[ 3224.915230] cmdq_prep_tran_desc: req: 0xffffffc0e3e16000 tag: 3 calc-link_desc: 0xffffff800a8b2800, sg-cnt: 1
[ 3224.915260] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220fe0 req: 0xffffffc0e3e17b00 mqrq: 0xffffffc0eb220de0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220fd8 card-addr: 0x00401140 dir(r-1/w-0): 0
[ 3224.915273] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915292] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x401140, intr: 1
[ 3224.915309] cmdq_prep_tran_desc: req: 0xffffffc0e3e17b00 tag: 4 calc-link_desc: 0xffffff800a8b3000, sg-cnt: 1
[ 3224.915339] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb221358 req: 0xffffffc0e3e16300 mqrq: 0xffffffc0eb221158 bytes to xf: 8192mmc_cmdq_req: 0xffffffc0eb221350 card-addr: 0x00401158 dir(r-1/w-0): 0
[ 3224.915352] mmc0: blksz 512 blocks 16 flags 00000100 tsac 400 ms nsac 0
[ 3224.915373] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000010 - addr: 0x401158, intr: 1
[ 3224.915392] cmdq_prep_tran_desc: req: 0xffffffc0e3e16300 tag: 5 calc-link_desc: 0xffffff800a8b3800, sg-cnt: 1
[ 3224.915420] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2216d0 req: 0xffffffc0e3e16180 mqrq: 0xffffffc0eb2214d0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2216c8 card-addr: 0x00401368 dir(r-1/w-0): 0
[ 3224.915433] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915453] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x401368, intr: 1
[ 3224.915468] cmdq_prep_tran_desc: req: 0xffffffc0e3e16180 tag: 6 calc-link_desc: 0xffffff800a8b4000, sg-cnt: 1
[ 3224.915499] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb221a48 req: 0xffffffc0e3e17080 mqrq: 0xffffffc0eb221848 bytes to xf: 28672mmc_cmdq_req: 0xffffffc0eb221a40 card-addr: 0x004019c0 dir(r-1/w-0): 0
[ 3224.915512] mmc0: blksz 512 blocks 56 flags 00000100 tsac 400 ms nsac 0
[ 3224.915531] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000038 - addr: 0x4019c0, intr: 1
[ 3224.915573] cmdq_prep_tran_desc: req: 0xffffffc0e3e17080 tag: 7 calc-link_desc: 0xffffff800a8b4800, sg-cnt: 1
[ 3224.915604] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb221dc0 req: 0xffffffc0e3e17200 mqrq: 0xffffffc0eb221bc0 bytes to xf: 32768mmc_cmdq_req: 0xffffffc0eb221db8 card-addr: 0x00401a00 dir(r-1/w-0): 0
[ 3224.915617] mmc0: blksz 512 blocks 64 flags 00000100 tsac 400 ms nsac 0
[ 3224.915637] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000040 - addr: 0x401a00, intr: 1
[ 3224.915673] cmdq_prep_tran_desc: req: 0xffffffc0e3e17200 tag: 8 calc-link_desc: 0xffffff800a8b5000, sg-cnt: 1
[ 3224.915702] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb222138 req: 0xffffffc0e58a4c00 mqrq: 0xffffffc0eb221f38 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb222130 card-addr: 0x00403330 dir(r-1/w-0): 0
[ 3224.915715] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915733] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x403330, intr: 1
[ 3224.915750] cmdq_prep_tran_desc: req: 0xffffffc0e58a4c00 tag: 9 calc-link_desc: 0xffffff800a8b5800, sg-cnt: 1
[ 3224.915778] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2224b0 req: 0xffffffc0e58a4a80 mqrq: 0xffffffc0eb2222b0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2224a8 card-addr: 0x004033d8 dir(r-1/w-0): 0
[ 3224.915790] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915810] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x4033d8, intr: 1
[ 3224.915826] cmdq_prep_tran_desc: req: 0xffffffc0e58a4a80 tag: 10 calc-link_desc: 0xffffff800a8b6000, sg-cnt: 1
[ 3224.915853] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb222828 req: 0xffffffc0e58a5980 mqrq: 0xffffffc0eb222628 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb222820 card-addr: 0x00801108 dir(r-1/w-0): 0
[ 3224.915866] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915884] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x801108, intr: 1
[ 3224.915901] cmdq_prep_tran_desc: req: 0xffffffc0e58a5980 tag: 11 calc-link_desc: 0xffffff800a8b6800, sg-cnt: 1
[ 3224.915929] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb222ba0 req: 0xffffffc0e58a5800 mqrq: 0xffffffc0eb2229a0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb222b98 card-addr: 0x00802138 dir(r-1/w-0): 0
[ 3224.915941] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.915956] *** mmc0: cmdq intr: 0x00004000
[ 3224.915974] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916067] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x802138, intr: 1
[ 3224.916087] cmdq_prep_tran_desc: req: 0xffffffc0e58a5800 tag: 12 calc-link_desc: 0xffffff800a8b7000, sg-cnt: 1
[ 3224.916120] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e58a5380 mqrq: 0xffffffc0eb220000 bytes to xf: 8192mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00802150 dir(r-1/w-0): 0
[ 3224.916133] mmc0: blksz 512 blocks 16 flags 00000100 tsac 400 ms nsac 0
[ 3224.916152] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000010 - addr: 0x802150, intr: 1
[ 3224.916172] cmdq_prep_tran_desc: req: 0xffffffc0e58a5380 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.916198] *** mmc0: cmdq intr: 0x00004000
[ 3224.916213] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916236] *** mmc0: cmdq intr: 0x00004000
[ 3224.916251] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916271] *** mmc0: cmdq intr: 0x00004000
[ 3224.916286] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916307] *** mmc0: cmdq intr: 0x00004000
[ 3224.916323] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916363] *** mmc0: cmdq intr: 0x00004000
[ 3224.916378] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916431] *** mmc0: cmdq intr: 0x00004000
[ 3224.916447] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916561] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb222f18 req: 0xffffffc0e58a4000 mqrq: 0xffffffc0eb222d18 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb222f10 card-addr: 0x00803c20 dir(r-1/w-0): 0
[ 3224.916572] *** mmc0: cmdq intr: 0x00004000
[ 3224.916585] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916712] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.916723] *** mmc0: cmdq intr: 0x00004000
[ 3224.916739] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916832] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x803c20, intr: 1
[ 3224.916852] cmdq_prep_tran_desc: req: 0xffffffc0e58a4000 tag: 13 calc-link_desc: 0xffffff800a8b7800, sg-cnt: 1
[ 3224.916869] *** mmc0: cmdq intr: 0x00004000
[ 3224.916884] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916917] *** mmc0: cmdq intr: 0x00004000
[ 3224.916932] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.916957] *** mmc0: cmdq intr: 0x00004000
[ 3224.916972] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.917079] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e58a5b00 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00804e88 dir(r-1/w-0): 0
[ 3224.917092] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.917112] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x804e88, intr: 1
[ 3224.917132] cmdq_prep_tran_desc: req: 0xffffffc0e58a5b00 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.917161] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2208f0 req: 0xffffffc0e58a5680 mqrq: 0xffffffc0eb2206f0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2208e8 card-addr: 0x00804ec0 dir(r-1/w-0): 0
[ 3224.917174] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.917192] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x804ec0, intr: 1
[ 3224.917209] cmdq_prep_tran_desc: req: 0xffffffc0e58a5680 tag: 2 calc-link_desc: 0xffffff800a8b2000, sg-cnt: 1
[ 3224.917228] *** mmc0: cmdq intr: 0x00004000
[ 3224.917243] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.917275] *** mmc0: cmdq intr: 0x00004000
[ 3224.917290] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.917330] *** mmc0: cmdq intr: 0x00004000
[ 3224.917346] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.917429] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e58a4480 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00804f48 dir(r-1/w-0): 0
[ 3224.917442] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.917462] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x804f48, intr: 1
[ 3224.917481] cmdq_prep_tran_desc: req: 0xffffffc0e58a4480 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.917510] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e58a5500 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00804f68 dir(r-1/w-0): 0
[ 3224.917523] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.917541] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x804f68, intr: 1
[ 3224.917558] cmdq_prep_tran_desc: req: 0xffffffc0e58a5500 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.917586] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220c68 req: 0xffffffc0e58a4900 mqrq: 0xffffffc0eb220a68 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220c60 card-addr: 0x00805038 dir(r-1/w-0): 0
[ 3224.917686] *** mmc0: cmdq intr: 0x00004000
[ 3224.917705] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.917807] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.917834] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x805038, intr: 1
[ 3224.917859] cmdq_prep_tran_desc: req: 0xffffffc0e58a4900 tag: 3 calc-link_desc: 0xffffff800a8b2800, sg-cnt: 1
[ 3224.917905] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e58a4600 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00805090 dir(r-1/w-0): 0
[ 3224.917916] *** mmc0: cmdq intr: 0x00004000
[ 3224.917938] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.918008] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918031] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x805090, intr: 1
[ 3224.918061] cmdq_prep_tran_desc: req: 0xffffffc0e58a4600 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.918101] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e58a4780 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00c01108 dir(r-1/w-0): 0
[ 3224.918122] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918144] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc01108, intr: 1
[ 3224.918165] cmdq_prep_tran_desc: req: 0xffffffc0e58a4780 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.918193] *** mmc0: cmdq intr: 0x00004000
[ 3224.918214] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.918305] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e47d3980 mqrq: 0xffffffc0eb220000 bytes to xf: 8192mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00c01130 dir(r-1/w-0): 0
[ 3224.918327] mmc0: blksz 512 blocks 16 flags 00000100 tsac 400 ms nsac 0
[ 3224.918351] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000010 - addr: 0xc01130, intr: 1
[ 3224.918380] cmdq_prep_tran_desc: req: 0xffffffc0e47d3980 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.918413] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2208f0 req: 0xffffffc0e47d3080 mqrq: 0xffffffc0eb2206f0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2208e8 card-addr: 0x00c011a8 dir(r-1/w-0): 0
[ 3224.918433] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918455] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc011a8, intr: 1
[ 3224.918476] cmdq_prep_tran_desc: req: 0xffffffc0e47d3080 tag: 2 calc-link_desc: 0xffffff800a8b2000, sg-cnt: 1
[ 3224.918495] *** mmc0: cmdq intr: 0x00004000
[ 3224.918510] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.918580] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e47d2180 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00c01218 dir(r-1/w-0): 0
[ 3224.918594] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918613] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc01218, intr: 1
[ 3224.918632] cmdq_prep_tran_desc: req: 0xffffffc0e47d2180 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.918660] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220c68 req: 0xffffffc0e47d3200 mqrq: 0xffffffc0eb220a68 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220c60 card-addr: 0x00c012b0 dir(r-1/w-0): 0
[ 3224.918673] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918691] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc012b0, intr: 1
[ 3224.918709] cmdq_prep_tran_desc: req: 0xffffffc0e47d3200 tag: 3 calc-link_desc: 0xffffff800a8b2800, sg-cnt: 1
[ 3224.918739] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220fe0 req: 0xffffffc0e47d3680 mqrq: 0xffffffc0eb220de0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220fd8 card-addr: 0x00c01390 dir(r-1/w-0): 0
[ 3224.918752] *** mmc0: cmdq intr: 0x00004000
[ 3224.918765] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.918824] *** mmc0: cmdq intr: 0x00004000
[ 3224.918837] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.918886] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918906] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc01390, intr: 1
[ 3224.918924] cmdq_prep_tran_desc: req: 0xffffffc0e47d3680 tag: 4 calc-link_desc: 0xffffff800a8b3000, sg-cnt: 1
[ 3224.918958] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e47d3500 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00c013c0 dir(r-1/w-0): 0
[ 3224.918970] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.918989] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc013c0, intr: 1
[ 3224.919006] cmdq_prep_tran_desc: req: 0xffffffc0e47d3500 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.919036] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2208f0 req: 0xffffffc0e47d2000 mqrq: 0xffffffc0eb2206f0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2208e8 card-addr: 0x00c013d0 dir(r-1/w-0): 0
[ 3224.919049] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.919067] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc013d0, intr: 1
[ 3224.919084] cmdq_prep_tran_desc: req: 0xffffffc0e47d2000 tag: 2 calc-link_desc: 0xffffff800a8b2000, sg-cnt: 1
[ 3224.919103] *** mmc0: cmdq intr: 0x00004000
[ 3224.919118] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919148] *** mmc0: cmdq intr: 0x00004000
[ 3224.919164] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919265] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e47d2f00 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00c01458 dir(r-1/w-0): 0
[ 3224.919278] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.919297] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc01458, intr: 1
[ 3224.919317] cmdq_prep_tran_desc: req: 0xffffffc0e47d2f00 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.919346] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220c68 req: 0xffffffc0e47d3800 mqrq: 0xffffffc0eb220a68 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220c60 card-addr: 0x00c014e8 dir(r-1/w-0): 0
[ 3224.919358] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.919377] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc014e8, intr: 1
[ 3224.919394] cmdq_prep_tran_desc: req: 0xffffffc0e47d3800 tag: 3 calc-link_desc: 0xffffff800a8b2800, sg-cnt: 1
[ 3224.919413] *** mmc0: cmdq intr: 0x00004000
[ 3224.919428] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919488] *** mmc0: cmdq intr: 0x00004000
[ 3224.919504] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919525] *** mmc0: cmdq intr: 0x00004000
[ 3224.919540] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919616] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e9378000 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00c01528 dir(r-1/w-0): 0
[ 3224.919629] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.919648] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc01528, intr: 1
[ 3224.919666] cmdq_prep_tran_desc: req: 0xffffffc0e9378000 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.919698] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e9379680 mqrq: 0xffffffc0eb220378 bytes to xf: 20480mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00c015b8 dir(r-1/w-0): 0
[ 3224.919711] mmc0: blksz 512 blocks 40 flags 00000100 tsac 400 ms nsac 0
[ 3224.919730] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000028 - addr: 0xc015b8, intr: 1
[ 3224.919772] cmdq_prep_tran_desc: req: 0xffffffc0e9379680 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.919799] *** mmc0: cmdq intr: 0x00004000
[ 3224.919818] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919843] *** mmc0: cmdq intr: 0x00004000
[ 3224.919863] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.919974] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e2b4bb00 mqrq: 0xffffffc0eb220000 bytes to xf: 8192mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00c01680 dir(r-1/w-0): 0
[ 3224.919995] mmc0: blksz 512 blocks 16 flags 00000100 tsac 400 ms nsac 0
[ 3224.920020] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000010 - addr: 0xc01680, intr: 1
[ 3224.920047] cmdq_prep_tran_desc: req: 0xffffffc0e2b4bb00 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.920081] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb2208f0 req: 0xffffffc0e2b4a780 mqrq: 0xffffffc0eb2206f0 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2208e8 card-addr: 0x00c07d98 dir(r-1/w-0): 0
[ 3224.920101] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.920124] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc07d98, intr: 1
[ 3224.920145] cmdq_prep_tran_desc: req: 0xffffffc0e2b4a780 tag: 2 calc-link_desc: 0xffffff800a8b2000, sg-cnt: 1
[ 3224.920170] *** mmc0: cmdq intr: 0x00004000
[ 3224.920190] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.920291] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220578 req: 0xffffffc0e2b4a180 mqrq: 0xffffffc0eb220378 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220570 card-addr: 0x00c08020 dir(r-1/w-0): 0
[ 3224.920311] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.920335] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc08020, intr: 1
[ 3224.920358] cmdq_prep_tran_desc: req: 0xffffffc0e2b4a180 tag: 1 calc-link_desc: 0xffffff800a8b1800, sg-cnt: 1
[ 3224.920391] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220c68 req: 0xffffffc0e2b4b200 mqrq: 0xffffffc0eb220a68 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb220c60 card-addr: 0x01006908 dir(r-1/w-0): 0
[ 3224.920412] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.920423] *** mmc0: cmdq intr: 0x00004000
[ 3224.920443] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.920522] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x1006908, intr: 1
[ 3224.920547] cmdq_prep_tran_desc: req: 0xffffffc0e2b4b200 tag: 3 calc-link_desc: 0xffffff800a8b2800, sg-cnt: 1
[ 3224.920565] *** mmc0: cmdq intr: 0x00004000
[ 3224.920581] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.920647] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e2b4b080 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x01801200 dir(r-1/w-0): 0
[ 3224.920660] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3224.920679] mmc0: cmdq_prep_task_desc: data-tag: 0x00000001 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0x1801200, intr: 1
[ 3224.920699] cmdq_prep_tran_desc: req: 0xffffffc0e2b4b080 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3224.920825] *** mmc0: cmdq intr: 0x00004000
[ 3224.920842] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.920870] *** mmc0: cmdq intr: 0x00004000
[ 3224.920882] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3224.933617] sdhci-tegra 3460000.sdhci: Setting clk limit 0
[ 3224.933623] sdhci-tegra 3460000.sdhci: Disabling clk 0, clk enabled 1
[ 3229.010405] sdhci-tegra 3460000.sdhci: Setting clk limit 196249804
[ 3229.010436] sdhci-tegra 3460000.sdhci: Enabling clk 200000000, clk enabled 0
[ 3229.013766] sdhci-tegra 3460000.sdhci: req clk 196249804, set clk 196249804
[ 3229.013834] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e2b4ad80 mqrq: 0xffffffc0eb220000 bytes to xf: 8192mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00c61300 dir(r-1/w-0): 0
[ 3229.013854] mmc0: blksz 512 blocks 16 flags 00000100 tsac 400 ms nsac 0
[ 3229.013882] mmc0: cmdq_prep_task_desc: data-tag: 0x00000000 - dir: 0 - prio: 0 - cnt: 0x00000010 - addr: 0xc61300, intr: 1
[ 3229.013923] cmdq_prep_tran_desc: req: 0xffffffc0e2b4ad80 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3229.014909] *** mmc0: cmdq intr: 0x00004000
[ 3229.014927] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3229.015908] *** mmc0: cmdq intr: 0x00004000
[ 3229.015916] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3229.015983] mmc0: mmc_blk_cmdq_rw_prep: mrq: 0xffffffc0eb220200 req: 0xffffffc0e92b2f00 mqrq: 0xffffffc0eb220000 bytes to xf: 4096mmc_cmdq_req: 0xffffffc0eb2201f8 card-addr: 0x00c61310 dir(r-1/w-0): 0
[ 3229.015989] mmc0: blksz 512 blocks 8 flags 00000100 tsac 400 ms nsac 0
[ 3229.016001] mmc0: cmdq_prep_task_desc: data-tag: 0x00000000 - dir: 0 - prio: 0 - cnt: 0x00000008 - addr: 0xc61310, intr: 1
[ 3229.016017] cmdq_prep_tran_desc: req: 0xffffffc0e92b2f00 tag: 0 calc-link_desc: 0xffffff800a8b1000, sg-cnt: 1
[ 3229.016774] *** mmc0: cmdq intr: 0x00004000
[ 3229.016783] mmc0: cmdq_irq: CQIS: 2, intmask: 4000
[ 3229.029717] sdhci-tegra 3460000.sdhci: Setting clk limit 0
[ 3229.029736] sdhci-tegra 3460000.sdhci: Disabling clk 0, clk enabled 1
The latest device tree for the above error messages:
fixed-regulators {
dummy_regulator_sdmmc3: regulator@19 {
compatible = "regulator-fixed";
reg = <19>;
regulator-name = "dummy_regulator_sdmmc3";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-always-on;
sdhci@3440000 {
nvidia,is-sdio;
cap-sdio-irq;
no-sd;
no-mmc;
only-1-8-v;
wakeup-source;
nvidia,disable-rtpm;
uhs-mask = <0x7F>; // Enables only SDR25 mode
max-clk-limit = <50000000>;
force-non-removable-rescan;
nvidia,vmmc-always-on;
vmmc-supply = <&spmic_sd2>;
nvidia,vqmmc-always-on;
vqmcc-supply = <&spmic_sd2>;
/delete-property/ ddr-clk-limit;
/delete-property/ no-sdio;
// /delete-property/ iommus;
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
/* Probably not needed as we do not have a cd/wp*/
nvidia,en-periodic-calib;
cd-inverted;
wp-inverted;
pwrdet-support;
wilc1000: wilc_wlan@1 {
compatible = "microchip,wilc1000", "microchip,wilc3000";
status = "okay";
reg = <1>;
pwr-retry-cnt = <4>;
sdhci-host = <&sdmmc3>;
irq-gpios = <&tegra_main_gpio TEGRA_MAIN_GPIO(C, 2) GPIO_ACTIVE_LOW>;
reset-gpio = <&tegra_main_gpio TEGRA_MAIN_GPIO(X, 4) GPIO_ACTIVE_LOW>;
chip_en-gpios = <&tegra_main_gpio TEGRA_AON_GPIO(U, 5) GPIO_ACTIVE_HIGH>;
Thanks in advance for your help!
