I wanted to know that whether we can connect 1TB external memory to Jetson?
Also I wanted to connect 4 camera as well. Suggest the best Jetson series for this purpose.
Since the topic is in Jetson Nano category, is the query specific to using Jetson Nano? Or you also consider use Orin series?
Hi I am open to all versions of Jetson which can be used for commercial purpose.
You may consider use either AGX Orin, Orin NX or Orin Nano. Please check
https://developer.nvidia.com/embedded/downloads#?search=design%20guide
Jetson AGX Orin Series Design Guide (including AGX Orin Industrial)
Jetson Orin NX Series and Orin Nano Series Design Guide
AGX Orin can support 4x 4-lane CSI cameras. Orin NX/Orin Nano can support 4x 2-lane CSI cameras.
For storage, you may use NVMe SSD. We have the M.2 Key M slot on AGX Orin and Orin Nano developer kits as reference design.
What about Jetson Xavier series?
Please check product design guide for Xavier series. The capability is different and you can choose the best fit for your use-case.
sure, thank you
