Connecting a camera module into Jetson Orin NX
Is there any workarounds for connecting this camera module (Wholesale 2MP 33x Global Shutter Network Zoom Camera Module Factory and Manufacturers | Huanyu) with Jetson Orin NX via its 36 pins FFC?
would an adaptor just work? is there any other solutions of that sort?
personally I doubt it does but just wanted to double check with people here
Hello @arkbbusiness ,
The best approach would be to ask the camera manufacturer if they sell an adapter for the 36 pin FFC connector that would allow you to expose the Network Connector the mention on their system specifications. The idea, would be to get the camera connected to the Orin NX through a regular network connection.
It seems like the camera supports ONVIF as the interface protocol, and other protocols for video transmission such as RTSP and RTP, therefore you should be able to interact and capture with the camera once you figure out the hardware connection.
So, to answer your question punctually, I would believe that with a hardware adapter you should be able to connect the camera to the Orin and use it.
Please keep us posted and let us know if you find an adapter that works in this case, this is very interesting.
best regards,
Andrew
