Hi everyone,
How to connect the Respeaker 4-Mic Array to the jetson nano. I found this online but i could not get it i’m new to the Jetson nano and linux.
I also tried following the steps in
I would appreciate your help.
Hi everyone,
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Hi almazyadmabdulmajeed,
Guidance on how to interface a new card with Jetson is available at link. Suggest you to go through this section to understand as to what changes need to be made to code for the same.
seeed-voicecard/README-jetson at jetson-respeaker-4mic-array-compatible · AshaTalambedu/seeed-voicecard · GitHub also lists the exact code to be taken in steps similar to those mentioned in BSP documentation. Suggest to give this a try after reading through above documentation and let us know if you face any issues
Thanks and Regards
Unfortunately I’m still facing the same issue.
Could you try suggestions in my earlier comment.
@atalambedu did you manage to solve your issue in the end?
Were you able to try out the suggestions in Connecting Respeaker 4-mic array for Raspberry Pi t o Jetson nano B01 - #4 by atalambedu?
