I am using Isaac Sim 5.1.0 with docker on Linux 22.04. I am trying to connect to the localhost to access the AWS servers in Isaac Sim 5.1.0. However, I cannot use the omniverse_launcher because I know it is depricated and connecting to localhost via nucleus does not work. Is there a way to connect to localhost without needing omniverse launcher which basically does not work anymore?
mhm112
1
lhuang
3
You can refer to the “Nucleus” section under Setup Tips — Isaac Sim Documentation for how to set the default Nucleus server.
Related topics
| I can not acces nucleus servers from my local instance | 3 | 1327 | January 11, 2021 | |
| Error to connect localhost | 7 | 1315 | February 20, 2024 | |
| I can't log in to the nucleus server from Isaac Sim | 7 | 4580 | July 28, 2021 | |
| Unable to connect to localhost | 2 | 781 | July 27, 2023 | |
| Unable to connect to localhost Nucleus from Python standalone application | 1 | 394 | April 19, 2026 | |
| Isaac Cannot connect to Nucleus | 7 | 1322 | June 30, 2022 | |
| Isaac Sim container with no Nucleus connected | 8 | 350 | January 17, 2025 | |
| Help me.... i can't install docker | 0 | 499 | May 21, 2022 | |
| Cannot access localhost in new release ISAAC SIM 2022.1 | 2 | 692 | July 25, 2022 | |
| Isaac Sim (2021.1.1) Wont Launch (Omniverse 1.3.4) | 22 | 4781 | December 20, 2021 |
