Isaac Cannot connect to Nucleus
I have not seen this issue in the other posts, so posting a new one here.
I am running ISAAC on AWS docker container. I was able to configure the Isaac folder on the nucleus and it is working fine over web UI.
However when starting up isaac sim, i am still getting errors like - ```2022-04-29 22:39:50 [43,332ms] [Warning] [omni.client.plugin] Tick: authentication: Discovery(ws://localhost:3333): Credentials service not found!
2022-04-29 22:39:50 [43,333ms] [Warning] [omni.isaac.core.utils.nucleus] Failure: Server omniverse://localhost does not have /Isaac folder
2022-04-29 22:39:50 [43,333ms] [Warning] [omni.isaac.core.utils.nucleus] /isaac/nucleus/default not specified in json config or via --/isaac/nucleus/default=“omniverse://my-nucleus-server” command line
2022-04-29 22:39:50 [43,333ms] [Warning] [omni.isaac.core.utils.nucleus] Attempting to locate server from previously saved servers…
2022-04-29 22:39:50 [43,333ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/savedServers setting not found
2022-04-29 22:39:50 [43,335ms] [Warning] [omni.client.plugin] Tick: authentication: Discovery(ws://127.0.0.1:3333): Credentials service not found!
2022-04-29 22:39:50 [43,336ms] [Warning] [omni.isaac.core.utils.nucleus] Failure: Server omniverse://127.0.0.1 does not have /Isaac folder
What should I check?
Thank you
simlar issue here
Do you still see this issue with the 2022.1.0 release? With the new release Isaac Sim container does not include Nucleus
@ltorabi thank you for the update
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/install_advanced.html
@ltorabi Could you extend where to download Linux launcher in order to follow the instruction for advanced docker aws implementation? It only suggests to install launcher on windows? Could you extend, please?
also it is unclear wher to download windows launcher
_av
you can download the launcher from here: Omniverse Enterprise Licensing & Pricing | NVIDIA
you can download windows or linux launcher, depends on which system you are working
@ltorabi
It doesn’t seem to run on headless Linux easily, unfortunately
 Setting InstallDir - /home/ubuntu/linux-x86_64/Web
/usr/bin/xdg-open: 851: /usr/bin/xdg-open: www-browser: not found
/usr/bin/xdg-open: 851: /usr/bin/xdg-open: links2: not found
/usr/bin/xdg-open: 851: /usr/bin/xdg-open: elinks: not found
/usr/bin/xdg-open: 851: /usr/bin/xdg-open: links: not found
/usr/bin/xdg-open: 851: /usr/bin/xdg-open: lynx: not found
/usr/bin/xdg-open: 851: /usr/bin/xdg-open: w3m: not found
xdg-open: no method available for opening 'omniverse-launcher://install?slug=navigator&check=false'
For Isaac Sim 2022.1.0, we recommend installing Nucleus from Launcher on a workstation. On a headless Linux setup, we recommend deploying the Omniverse Enterprise Nucleus docker stack.
