I am new to ISAAC SIM. I am using the cloud Azure VM with the local Omniverse Streaming Client.
The problem occurred when I wanted to import a local model, it seems that I was using the Isaac Sim container with no Nucleus connected.
Then open ISAAC SIM in live streaming mode. However, the ISAAC SIM in the Azure VM still cannot access files in the local Windows system, and cannot even connect to the Nucleus.
I think this point mentioned in the link is the problem I am facing :(
Also, the two videos in this comment should be related to this, I tried the steps of the second video, but when I use Nucleus in my windows host, I can open the first link normally:
However, the second and third links don’t seem to work:
localhost:8080
and
<ip_address>:8080
It seems that I can manage shared users through this link, But I am not sure if the same is true for communication between Azure VM and local Windows host.
To ensure we’re on the same page and to provide the most accurate assistance, I’d like to clarify your desired connection setup:
It seems you’re trying to achieve the following:
Run Isaac Sim on a remote Azure VM
Connect this Isaac Sim instance to a Nucleus server running on your local Windows 10 machine
Import local models from your Windows 10 system into the Isaac Sim environment on Azure
So if I want to start Isaac Sim with native livestream mode, I can’t use the local model from my Windows system. If I want to import the local model, I can only choose Workstation Installation, right?
