Hi, I have Jetson AGX Orin 64GB Developer Kit. I wonder if I have option after headless setup to define username, hostname and password to connect from host device to flashed Orin with SSH.
I’m using these commands
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v4.1/release/jetson_linux_r35.4.1_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/l4t/r35_release_v4.1/release/tegra_linux_sample-root-filesystem_r35.4.1_aarch64.tbz2
tar xf jetson_linux_r35.4.1_aarch64.tbz2
sudo tar xpf tegra_linux_sample-root-filesystem_r35.4.1_aarch64.tbz2 -C Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./apply_binaries.sh
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_nvme.xml --external-only --showlogs jetson-agx-orin-devkit external
It says
Reboot target
Run command: sync; nohup reboot &>/dev/null & exit on root@fe80::1%usb0
SSH is not ready
Reboot failed.
Cleaning up...
I can attach Orin to display and set username, hostname, password btw.
