Connecting video grabber M.2 to Jetson Orin Nano
We have a Jetson Orin Nano developer kit and we have connected a video grabber in the M2 PCie slot to take input from a couple of cameras.
The video grabber is the Eco Capture Dual SDI M.2 from Magewell.
We have installed the drivers for the Magewell video grabber but do not see the video grabber when we type ‘lsusb’ in the terminal.
Nor can we detect the cameras connected to the video grabber in /dev/video*.
The Jetson Orin Nano is running Jetpack 5.1.2
Are we missing any steps to enable the devices connected to the m2 slot? Does it need any changes in the device tree?
It looks to be connected to PCIe interface. Please run sudo lspci -v and check if the device is detected/listed.
Thank you, @DaneLLL
We were unable to detect the device with lspci -v either.
It turns out the video device was faulty. Replacing the device worked.
