What are the GPIO Pins in Jetson nano that I will be able send commands to RMCS 1120 (Stepper motor driver).
The pins in RMCS 1120 driver are:
PUL+
PUL-
DIR+
DIR-
ENA+
ENA-
The above-mentioned pins I have to connect to the GPIO Pins on Jetson nano.
Tell me the GPIO Pins that I make a connection between the Jetson Nano and the RMCS 1120 driver.
Are you a collague of this guy?
@DaveYYY
yes,
is it possible to control three RMCS 1120 drivers with one Jetson nano board?
I don’t know. Maybe YES if you have enough GPIO pins available.
Please test it yourself.
@DaveYYY
Jetson nano have only 2 PWM pins (32, 33) in GPIO?
I don’t really know what you want to use.
You ask about GPIO in the first, and then you ask about PWM now.
Please check it yourself in the pinmux spreadsheet.
