I have two identical servers:
Platform: Gigabyte R282-Z92
CPU: 2 x AMD Epyc 7282
Memory: 2TB
Drives: 24 x Micron 9300 MAX NVMe
System drive: 1 x WDC SN720 M.2
Network: 2 x MCX4121A-ACAT
System is set to UEFI (also on MCX card I have enabled UEFI_HII_EN and EXP_ROM_UEFI_x86_ENABLE). On first system I have installed VMware ESXi 6.7 and everything is working, all network cards are visible. On second system I have installed FreeBSD 12.1 and have problem with activating Mellanox interfaces.
I’m able to use MFT utils on FreeBSD, flash newer firmware, fetch config/information, set parameters, but loading mlx5en module returns only errors and no any Mellanox interface appears when checking with ifconfig.
Here is output from module load:
Attached also logs from tools.
Any ideas how to start these interfaces?
Regards
Artur
dmesg.txt (35.3 KB)
mlxfwmanager.txt (1.07 KB)
kldstat.txt (581 Bytes)
mlxconfig_q.txt (16 KB)
