ConnectX-8 NIC split to 8 total 10G ports
I would like to use breakout cables to connect multiple devices with 10G ports to a ConnectX-8 C8240 network card with qsfp to sfp breakout cables. I see that this NIC supports configuration for 8 Ethernet ports. I have run the mlxconfig commands but only see 5 ports (vs 2 originally) and have not been able to get the ports to negotiate. Help would be appreciated as I’m very new to this.
sudo mlxlink -d /dev/mst/mt4131_pciconf0.3
Operational Info
State                              : Receiver detect
Physical state                     : ETH_AN_FSM_ENABLE
Speed                              : N/A
Width                              : N/A
FEC                                : N/A
Loopback Mode                      : No Loopback
Auto Negotiation                   : ON
Supported Info
Enabled Link Speed (Ext.)          : 0x00000952 (100G_1X,50G_1X,25G,10G,1G)
Supported Cable Speed (Ext.)       : 0x00000032 (40G,10G,1G)
Troubleshooting Info
Status Opcode                      : 2
Group Opcode                       : PHY FW
Recommendation                     : Negotiation failure
Tool Information
Firmware Version                   : 40.45.1202
amBER Version                      : 6.4
MFT Version                        : 4.35.0-159
Hi
  1. Each QSFP112 port on C8240 is built from 4 × 100 G PAM4 electrical lanes
  2. These lanes are designed to:
    • Aggregate upward (400 G / 2×400 G)
    • Split only to supported Ethernet breakouts (e.g., 2×200 G or 4×100 G)
Thanks,
Suo
Are you sure? This page seems to indicate that they can support NRZ and lower rates: Linking DGXs, Switches, ConnectX-7 & ConnectX-8 Adapters, and BlueField-3 DPUs Overview - NVIDIA Docs
“4-channel QSFP112 (4x100G-PAM4) cages can support QSFP56 (4x50G-PAM4) and QSFP28 (4x25G-NRZ) devices”
I’m not sure this means what I think it means; I’m happy to be corrected. Thanks for the reply and any future guidance.
Hi William,
Yes, it can support 4x25G NRZ.
However, you can only split CX8 standard card port into four ports due to a hardware limitation.
Thanks,
Suo
