Port splitting (100G to 4x25G) support on ConnectX-5 MCX516A-CDAT
Hi all,
I am trying to use a 100GbE to 4x25GbE breakout cable with a ConnectX-5. My goal is to configure the NIC to treat a single 100G port as four separate 25G logical interfaces.
Is this hardware capable of port-splitting? If so, what are the mlxconfig commands needed to enable it?
Device Info:
  • NIC: ConnectX-5 Ex EN (MCX516A-CDA)
  • OS: Ubuntu 22.04.5 LTS
mlxconfig -d 0000:01:00.0 query
Device #1:
Device type:        ConnectX5
Description:        ConnectX-5 Ex EN network interface card; 100GbE dual-port QSFP28; PCIe4.0 x16; tall bracket; ROHS R6
Device:             0000:01:00.0
All thoughts are appreciated.
Hello Suraj_Chalapathy,
Thank you for posting your inquiry to the NVIDIA Developer Forums.
Unfortunately, split mode configuration is not supported on the adapter.
Those breakout cables are intended for use with switches - example, splitting out a single 100gbps switch port into 4x25gbps links towards the hosts.
Best regards,
NVIDIA Enterprise Experience
