ConnectX-8 to QM9700 Interconnect
When connecting a CX-8 SuperNIC 800G XDR 1Port (P/N: 900-9X81E-00EX-ST0) to a QM9700 switch,
is the following connection possible?
CX-8 SuperNIC + MMS4A20-XM800 (transceiver) <----------Cable-------------> (MMS4X00-NS) QM9700
This is intended for 400G NDR communication.
Or should we instead use the MMA4Z00-NS400 transceiver for the CX-8 SuperNIC?
You need to use MMA4Z00-NS400 to connect to a NDR switch, MMS4A20-XM800 is used for XDR.
Thanks,
Suo
