Greetings,
I do have an installation of an older cluster using Qlogic 12200-BS01 QDR IB switches which I would like to have it connected to the newer cluster which is using the NVidia Mellanox QM8700 HDR switches.
Somewhere I have read that one can only connect the two switches ( QDR → HDR) using a “jumper” FDR switch: QDR → FDR → HDR
Is this true? any specificities I need to be aware? I don’t have the FDR switch and I will need to purchase one: any suggestion on what FDR model number is very welcomed!
The new cluster and the old cluster are separated by two cabinet rows in the data center - maybe 20ft distance.
I can place the FDR switch close to the HDR switches, and use longer cables to reach the QDR switches.
What type of cables do I need to connect the FDR IB switch to the HDR IB switch?
What type of cables do I need to connect the FDR IB switch to the QDR switches?
Part numbers for the cables needed will be very helpful!
Thank you!
