torel2
October 5, 2022, 7:56pm
1
I’ve connected an FDR switch SX6025 (leaf) to HDR switch QM8790 (tor). The connection works fine (seeing beegfs ib rdma on libvirt nodes), but when trying to query or update the firmware of SwitchX, I get
root@v001:~# flint -d /dev/mst/SW_MT51000_SwitchX_lid-0x0041 q
FATAL - Can’t find device id.
-E- Cannot open Device: /dev/mst/SW_MT51000_SwitchX_lid-0x0041. MFE_UNSUPPORTED_DEVICE
HCA’s are all updated to the latest Connect-X3 firmware.
Any suggestions on how I can update the firmware of this MSX6025F-1SFR?
I’m using FDR cables. Suggestions?
Reference:
Hi there. We just bought a new cluster with 8790 HDR switch recently, and I wanted to integrate the old cluster as well. Since the nodes of the old clusters are connected to a 6025 FDR switch, so I just connected the two switches with two EDR cables. Everything else was fine, but iblinkinfo suggests that the connection between two switches are just 10Gb
24 35 ==( 4X 2.5 Gbps Active/ LinkUp)==> 11 79 “Quantum Mellanox Technologies” ( Could be 14.0625 Gbps)
24 36 ==( 4X 2.5 Gbps Active/ LinkUp)=…
Hi, Tore,
Could you let us know the mft tool version are you use ?
Thanks,
