Constant Vector3D node not available in isaac sim interface
Hi All,
I am trying to develop an action graph in Isaac sim , just going through the general documentation but there seems to be some error while importing the Constant Vec3d Node. The node is not showing up even after searching it in the search bar.
The Isaac sim version that I am currently using is : 2022.1.0 Beta.
Constant Float3 or Double3 should work. I believe the omniverse team renamed the Vec3d node
