I’m attempting to convert an mp4 to RGB using GST. I get the following data when piping to the fake sink.
$ gst-launch-1.0 -v filesrc location=./test.mp4 ! decodebin ! fakesink silent=False
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/quicktime
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = NULL
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstPad:src_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)2.1, profile=(string)constrained-baseline, codec_data=(buffer)014240150301000b6742402895a01e0089f95001000468ce3c80, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)2.1, profile=(string)constrained-baseline, codec_data=(buffer)014240150301000b6742402895a01e0089f95001000468ce3c80, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstMultiQueue:multiqueue0.GstMultiQueuePad:sink_0: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, level=(string)2.1, profile=(string)constrained-baseline, codec_data=(buffer)014240150301000b6742402895a01e0089f95001000468ce3c80, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0.GstPad:src: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)6250/207
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: stream-start (10254), GstEventStreamStart, stream-id=(string)449ab9831a644fbdbee1615ed92715dd9f4a93b7922395ec46b6172391c3ce98/001, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)2;) 0x7f8400c010
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: caps (12814), GstEventCaps, caps=(GstCaps)“video/x-raw(memory:NVMM),\ format=(string)NV12,\ width=(int)1920,\ height=(int)1080,\ interlace-mode=(string)progressive,\ multiview-mode=(string)mono,\ multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono,\ pixel-aspect-ratio=(fraction)1/1,\ chroma-site=(string)mpeg2,\ colorimetry=(string)bt709,\ framerate=(fraction)6250/207”;) 0x7f8400c6c0
/GstPipeline:pipeline0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)6250/207
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad2: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)bt709, framerate=(fraction)6250/207
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: segment (17934), GstEventSegment, segment=(GstSegment)“GstSegment, flags=(GstSegmentFlags)GST_SEGMENT_FLAG_NONE, rate=(double)1, applied-rate=(double)1, format=(GstFormat)GST_FORMAT_TIME, base=(guint64)0, offset=(guint64)0, start=(guint64)0, stop=(guint64)5596000000, time=(guint64)0, position=(guint64)0, duration=(guint64)18446744073709551615;”;) 0x7f8400c320
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: tag (20510), GstTagList-stream, taglist=(taglist)“taglist,\ video-codec=(string)"H.264\\ /\\ AVC",\ bitrate=(uint)2590869;”;) 0x7f78008490
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: tag (20510), GstTagList-global, taglist=(taglist)“taglist,\ datetime=(datetime)2023-11-19T21:05:39Z,\ container-format=(string)Quicktime;”;) 0x7f8400c240
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: tag (20510), GstTagList-stream, taglist=(taglist)“taglist,\ video-codec=(string)"H.264\\ \(Constrained\\ Baseline\\ Profile\)",\ bitrate=(uint)2590869;”;) 0x7f78008570
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = preroll *******
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (1008 bytes, dts: none, pts: 0:00:00.000000000, duration: 0:00:00.033120000, offset: -1, offset_end: -1, flags: 00000440 discont header , meta: GstVideoMeta) 0x7f88030e70
(omitting lines for brevity)
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: tag (20510), GstTagList-stream, taglist=(taglist)“taglist,\ video-codec=(string)"H.264\\ \(Constrained\\ Baseline\\ Profile\)",\ bitrate=(uint)2590869,\ minimum-bitrate=(uint)3184541,\ maximum-bitrate=(uint)3184541;”;) 0x7f78008ed0
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = chain ******* (fakesink0:sink) (1008 bytes, dts: none, pts: 0:00:00.295333333, duration: 0:00:00.033120000, offset: -1, offset_end: -1, flags: 00000000 , meta: GstVideoMeta) 0x7f88030e70
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: stream-group-done (26894), GstEventStreamGroupDone, group-id=(uint)2;) 0x7f780c5570
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: eos (28174), ) 0x7f8400c420
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.537895455
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
From this output, it seems I could add videoconvert ! video/x-raw,format=RGB and convert to RGB. However, I get the following error when doing so:
$ gst-launch-1.0 -v filesrc location=./test.mp4 ! decodebin ! videoconvert ! video/x-raw,format=RGB ! fakesink silent=False
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)4, profile=(string)constrained-baseline, width=(int)1920, height=(int)1080, framerate=(fraction)6250/207, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
/GstPipeline:pipeline0/GstFakeSink:fakesink0: last-message = event ******* (fakesink0:sink) E (type: stream-start (10254), GstEventStreamStart, stream-id=(string)449ab9831a644fbdbee1615ed92715dd9f4a93b7922395ec46b6172391c3ce98/001, flags=(GstStreamFlags)GST_STREAM_FLAG_NONE, group-id=(uint)2;) 0x7f9000e010
WARNING: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1: not negotiated
Additional debug info:
gstbasetransform.c(1415): gst_base_transform_reconfigure (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1:
not negotiated
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0: Internal data stream error.
qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn’t want to preroll.
Freeing pipeline …
Any suggestions for getting this decoded to RGB?
