Is there a step by step process for transferring everything from an SD card to an SSD and using that in place of the SD to boot?
Also, is there a simple process to switch between using only SD or only SSD (assuming both have the bsp and such installed)?
We have Flashing Support — NVIDIA Jetson Linux Developer Guide cloning rootfs section to create system.img.raw and flash to other storage.
Please refer to this topics to change boot order
system
Closed
5
