Since we need set up a radiated test system to check if the wifi parts work well which contain the TX2 and antenna and related cables. and other wifi modules have the AT command to set the module on some special mode. So we want to check if TX2’s wifi part could be controled by some command? Thanks
Hi niuzhichao,
Please refer to Jetson TX1-TX2 OEM Wireless Compliance Guide
Got it , thanks a lot for your help.
Hi Kayccc,
There is no control command could be found in the document. Could the TX2’wifi be controled to send out power in non signalling mode? Thanks
Hi niuzhichao,
All the information at in that doc, and you may need to help from suggested lab to do the experiment.
