problem installing onnxsim on jetson agx orin.
CUDA - 11.4.315
TensorRT- 8.5.2.2
Torch- 1.14.0a0+44dac51c.nv23.2
Onnxruntime- 1.14.0
(vir_env) nvidia@yuan-6n0:/media/nvidia/45e64ab1-5e36-4ac2-bfc7-6bbeca4458a8/cuda_codes$ pip3 install onnxsim
Collecting onnxsim
Using cached onnxsim-0.4.36.tar.gz (21.0 MB)
Preparing metadata (setup.py) … done
Requirement already satisfied: onnx in /home/nvidia/vir_env/lib/python3.8/site-packages (from onnxsim) (1.17.0)
Collecting rich (from onnxsim)
Using cached rich-14.2.0-py3-none-any.whl.metadata (18 kB)
Requirement already satisfied: numpy>=1.20 in /home/nvidia/vir_env/lib/python3.8/site-packages (from onnx->onnxsim) (1.24.4)
Requirement already satisfied: protobuf>=3.20.2 in /home/nvidia/vir_env/lib/python3.8/site-packages (from onnx->onnxsim) (5.29.5)
Collecting markdown-it-py>=2.2.0 (from rich->onnxsim)
Using cached markdown_it_py-3.0.0-py3-none-any.whl.metadata (6.9 kB)
Collecting pygments<3.0.0,>=2.13.0 (from rich->onnxsim)
Using cached pygments-2.19.2-py3-none-any.whl.metadata (2.5 kB)
Collecting mdurl~=0.1 (from markdown-it-py>=2.2.0->rich->onnxsim)
Using cached mdurl-0.1.2-py3-none-any.whl.metadata (1.6 kB)
Using cached rich-14.2.0-py3-none-any.whl (243 kB)
Using cached markdown_it_py-3.0.0-py3-none-any.whl (87 kB)
Using cached pygments-2.19.2-py3-none-any.whl (1.2 MB)
Using cached mdurl-0.1.2-py3-none-any.whl (10.0 kB)
Building wheels for collected packages: onnxsim
Building wheel for onnxsim (setup.py) … error
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [185 lines of output]
/tmp/pip-install-d5nbrj21/onnxsim_90cb0fe09407401a842b579e6bfbf5c2/setup.py:28: DeprecationWarning: Use shutil.which instead of find_executable
CMAKE = find_executable(‘cmake’)
fatal: not a git repository (or any of the parent directories): .git
/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/_init_.py:94: _DeprecatedInstaller: setuptools.installer and fetch_build_eggs are deprecated.
Requirements should be satisfied by a PEP 517 installer.
If you are using pip, you can try \`pip install --use-pep517\`.
dist.fetch_build_eggs(dist.setup_requires)
running bdist_wheel
running build
running build_py
running create_version
creating build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/model_checking.py -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/version.py -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/\__main_\_.py -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/model_info.py -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/onnx_simplifier.py -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/\__init_\_.py -> build/lib.linux-aarch64-cpython-38/onnxsim
running egg_info
writing onnxsim.egg-info/PKG-INFO
writing dependency_links to onnxsim.egg-info/dependency_links.txt
writing entry points to onnxsim.egg-info/entry_points.txt
writing requirements to onnxsim.egg-info/requires.txt
writing top-level names to onnxsim.egg-info/top_level.txt
reading manifest file 'onnxsim.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '\*.c' under directory 'onnxsim'
warning: no files found matching '\*.proto' under directory 'onnxsim'
warning: no previously-included files matching '\*' found under directory 'third_party/onnxruntime'
warning: no previously-included files matching '\*' found under directory 'third_party/onnx-optimizer/build'
warning: no previously-included files matching '\*' found under directory 'third_party/onnx/build'
warning: no previously-included files matching '\*' found under directory 'third_party/onnx/onnx/backend'
adding license file 'LICENSE'
writing manifest file 'onnxsim.egg-info/SOURCES.txt'
/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/command/build_py.py:220: \_Warning: Package 'onnxsim.bin' is absent from the \`packages\` configuration.
# Package would be ignored #
Python recognizes 'onnxsim.bin' as an importable package\[^1\],
but it is absent from setuptools' \`packages\` configuration.
This leads to an ambiguous overall configuration. If you want to distribute this
package, please make sure that 'onnxsim.bin' is explicitly added
to the \`packages\` configuration field.
Alternatively, you can also rely on setuptools' discovery methods
(for example by using \`find_namespace_packages(...)\`/\`find_namespace:\`
instead of \`find_packages(...)\`/\`find:\`).
You can read more about "package discovery" on setuptools documentation page:
- https://setuptools.pypa.io/en/latest/userguide/package_discovery.html
If you don't want 'onnxsim.bin' to be distributed and are
already explicitly excluding 'onnxsim.bin' via
\`find_namespace_packages(...)/find_namespace\` or \`find_packages(...)/find\`,
you can try to use \`exclude_package_data\`, or \`include-package-data=False\` in
combination with a more fine grained \`package-data\` configuration.
You can read more about "package data files" on setuptools documentation page:
- https://setuptools.pypa.io/en/latest/userguide/datafiles.html
\[^1\]: For Python, any directory (with suitable naming) can be imported,
even if it does not contain any \`.py\` files.
On the other hand, currently there is no concept of package data
directory, all directories are treated like packages.
check.warn(importable)
copying onnxsim/cpp2py_export.cc -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/cxxopts.hpp -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/onnxsim.cpp -> build/lib.linux-aarch64-cpython-38/onnxsim
copying onnxsim/onnxsim.h -> build/lib.linux-aarch64-cpython-38/onnxsim
creating build/lib.linux-aarch64-cpython-38/onnxsim/bin
copying onnxsim/bin/onnxsim_bin.cpp -> build/lib.linux-aarch64-cpython-38/onnxsim/bin
copying onnxsim/bin/onnxsim_option.cpp -> build/lib.linux-aarch64-cpython-38/onnxsim/bin
copying onnxsim/bin/onnxsim_option.h -> build/lib.linux-aarch64-cpython-38/onnxsim/bin
running build_ext
running cmake_build
Run command \['/home/nvidia/vir_env/bin/cmake', '-DPython_INCLUDE_DIR=/usr/include/python3.8', '-DPython_EXECUTABLE=/home/nvidia/vir_env/bin/python3', '-DPYTHON_EXECUTABLE=/home/nvidia/vir_env/bin/python3', '-DBUILD_ONNX_PYTHON=OFF', '-DONNXSIM_PYTHON=ON', '-DONNXSIM_BUILTIN_ORT=OFF', '-DONNX_USE_LITE_PROTO=OFF', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', '-DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cpython-38-aarch64-linux-gnu.so', '-DONNX_OPT_USE_SYSTEM_PROTOBUF=OFF', '-DCMAKE_BUILD_TYPE=Release', '-DONNX_ML=1', '/tmp/pip-install-d5nbrj21/onnxsim_90cb0fe09407401a842b579e6bfbf5c2'\]
-- The CXX compiler identification is GNU 9.4.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- The C compiler identification is GNU 9.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
CMake Deprecation Warning at third_party/onnx-optimizer/third_party/protobuf/cmake/CMakeLists.txt:2 (cmake_minimum_required):
Compatibility with CMake < 3.10 will be removed from a future version of
CMake.
Update the VERSION argument <min> value. Or, use the <min>...<max> syntax
to tell CMake that the project requires at least <min> but has been updated
to work with policies introduced by <max> or earlier.
-- 3.20.1.0
-- Performing Test protobuf_HAVE_LD_VERSION_SCRIPT
-- Performing Test protobuf_HAVE_LD_VERSION_SCRIPT - Success
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found version "1.2.11")
-- Performing Test protobuf_HAVE_BUILTIN_ATOMICS
-- Performing Test protobuf_HAVE_BUILTIN_ATOMICS - Success
CMake Error at third_party/onnx-optimizer/third_party/onnx/CMakeLists.txt:2 (cmake_minimum_required):
Compatibility with CMake < 3.5 has been removed from CMake.
Or, add -DCMAKE_POLICY_VERSION_MINIMUM=3.5 to try configuring anyway.
-- Configuring incomplete, errors occurred!
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/tmp/pip-install-d5nbrj21/onnxsim_90cb0fe09407401a842b579e6bfbf5c2/setup.py", line 279, in <module>
setuptools.setup(
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\__init_\_.py", line 117, in setup
return distutils.core.setup(\*\*attrs)
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\_distutils/core.py", line 183, in setup
return run_commands(dist)
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\_distutils/core.py", line 199, in run_commands
dist.run_commands()
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\_distutils/dist.py", line 954, in run_commands
self.run_command(cmd)
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/dist.py", line 999, in run_command
super().run_command(command)
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\_distutils/dist.py", line 973, in run_command
cmd_obj.run()
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/command/bdist_wheel.py", line 400, in run
self.run_command("build")
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\_distutils/cmd.py", line 316, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/home/nvidia/vir_env/lib/python3.8/site-packages/setuptools/\_distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-install-d5nbrj21/onnxsim_90cb0fe09407401a842b579e6bfbf5c2/setup.py", line 220, in run
self.run_command('cmake_build')
cmd_obj.run()
File "/tmp/pip-install-d5nbrj21/onnxsim_90cb0fe09407401a842b579e6bfbf5c2/setup.py", line 194, in run
subprocess.check_call(cmake_args)
File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '\['/home/nvidia/vir_env/bin/cmake', '-DPython_INCLUDE_DIR=/usr/include/python3.8', '-DPython_EXECUTABLE=/home/nvidia/vir_env/bin/python3', '-DPYTHON_EXECUTABLE=/home/nvidia/vir_env/bin/python3', '-DBUILD_ONNX_PYTHON=OFF', '-DONNXSIM_PYTHON=ON', '-DONNXSIM_BUILTIN_ORT=OFF', '-DONNX_USE_LITE_PROTO=OFF', '-DCMAKE_EXPORT_COMPILE_COMMANDS=ON', '-DONNX_NAMESPACE=onnx', '-DPY_EXT_SUFFIX=.cpython-38-aarch64-linux-gnu.so', '-DONNX_OPT_USE_SYSTEM_PROTOBUF=OFF', '-DCMAKE_BUILD_TYPE=Release', '-DONNX_ML=1', '/tmp/pip-install-d5nbrj21/onnxsim_90cb0fe09407401a842b579e6bfbf5c2'\]' returned non-zero exit status 1.
\[end of output\]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for onnxsim
Running setup.py clean for onnxsim
Failed to build onnxsim
ERROR: Failed to build installable wheels for some pyproject.toml based projects (onnxsim)
