Could not load %1 edid
I have Hardware using 4 graphic cards Quadro P4000 each port in the graphic cards is connected to screen.
I Exported EDID file from one port already connected to screen.
When i try to load this EDID file to the ports from “Nividia Control panel - View system topology” i get error text that i never saw before saying “Could not load %1 EDID” as per attached photo.
Can someone help me, Need to succesfully load EDID file to all used ports in the graphic cards.
Hi, I had the same problem recently. I tried to attach the edid to the outputs of a video card that had mosaic configured. First you need to disable the mosaic configuration if it is enabled.
