Hi
I tried to flash Xavier with Jetpack 4.1 and I get the following error
“CPU Bootloader is not running on the device”
My host machine is x86 running on Ubuntu 16.04 without VMs. Did anyone have the same error and does anyone know how to fix it?
Hi Cookie007,
We don’t hit this issue before.
Could you share your steps first? Thanks!
I downloaded the Jetpack 4.1 and followed all steps till it asks me to put the system in recovery mode. Once I detect Nvidia Corp in lsusb; I start the flashing process and then it stops at Bootloader. I have tried this using a different host machine running Ubuntu 16.04 and Ubuntu 18.04 but I get the same error. I have attached my flashing log below:
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0279 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0295 ] Assuming zero filled SBK key
[ 0.0372 ]
[ 0.0373 ] Generating RCM messages
[ 0.0435 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0450 ] Header already present for mb1_t194_prod.bin
[ 0.0564 ]
[ 0.0579 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0591 ] Assuming zero filled SBK key
[ 0.0593 ]
[ 0.1289 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.1837 ]
[ 0.3323 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.3341 ] RCM 0 is saved as rcm_0.rcm
[ 0.3422 ] RCM 1 is saved as rcm_1.rcm
[ 0.3422 ] RCM 2 is saved as rcm_2.rcm
[ 0.3422 ] List of rcm files are saved in rcm_list.xml
[ 0.3422 ]
[ 0.3422 ] Signing RCM messages
[ 0.3439 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.3459 ] Assuming zero filled SBK key
[ 0.3468 ]
[ 0.3468 ] Copying signature to RCM mesages
[ 0.3486 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.5251 ]
[ 0.5252 ] Parsing partition layout
[ 0.5729 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.5884 ]
[ 0.5884 ] Creating list of images to be signed
[ 0.5897 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.5908 ] MB1: Nvheader already present
[ 0.5913 ] MB1: Nvheader already present
[ 1.3226 ] adding BCH for spe_t194.bin
[ 1.7036 ] adding BCH for spe_t194.bin
[ 1.7066 ] adding BCH for nvtboot_t194.bin
[ 1.7199 ] adding BCH for nvtboot_t194.bin
[ 1.7253 ] Header already present for preboot_c10_prod_cr.bin
[ 1.7356 ] Header already present for preboot_c10_prod_cr.bin
[ 1.7359 ] Header already present for mce_c10_prod_cr.bin
[ 1.7411 ] Header already present for mce_c10_prod_cr.bin
[ 1.7449 ] adding BCH for mts_c10_prod_cr.bin
[ 1.7767 ] adding BCH for mts_c10_prod_cr.bin
[ 1.8864 ] adding BCH for cboot_t194.bin
[ 1.9917 ] adding BCH for cboot_t194.bin
[ 2.0025 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.0140 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.0221 ] adding BCH for tos_t194.img
[ 2.0528 ] adding BCH for tos_t194.img
[ 2.0558 ] adding BCH for eks.img
[ 2.0654 ] adding BCH for bpmp_t194.bin
[ 2.0834 ] adding BCH for bpmp_t194.bin
[ 2.1122 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 2.1612 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 2.1726 ] adding BCH for camera-rtcpu-rce.bin
[ 2.2125 ] adding BCH for camera-rtcpu-rce.bin
[ 2.2208 ] Header already present for warmboot_t194_prod.bin
[ 2.2298 ] Header already present for warmboot_t194_prod.bin
[ 2.2319 ]
[ 2.2319 ] Filling MB1 storage info
[ 2.2320 ] Generating br-bct
[ 2.2335 ] Performing cfg overlay
[ 2.2335 ] [‘tegra194-mb1-bct-memcfg-p2888.cfg’, ‘tegra194-memcfg-sw-override.cfg’]
[ 2.2345 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/robertml/Desktop/xav/Xavier/L
[ 2.6575 ]
[ 2.6576 ] Updating dev and MSS params in BR BCT
[ 2.6576 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5O
[ 2.6821 ]
[ 2.6821 ] Updating bl info
[ 2.6835 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 2.6847 ] BCH present 250784
[ 2.6853 ] StartBlock 2
[ 2.6853 ] StartPage 8
[ 2.6854 ] BCH present 250784
[ 2.6858 ] StartBlock 18
[ 2.6859 ] StartPage 8
[ 2.6866 ]
[ 2.6866 ] Generating signatures
[ 2.6878 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.6889 ] Assuming zero filled SBK key
[ 2.7101 ]
[ 2.7101 ] Generating br-bct
[ 2.7113 ] Performing cfg overlay
[ 2.7113 ] [’/home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1.cfg’]
[ 2.7113 ] Updating dev and MSS params in BR BCT
[ 2.7113 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5O
[ 2.7303 ]
[ 2.7303 ] Updating bl info
[ 2.7313 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 2.7321 ] BCH present 250784
[ 2.7326 ] StartBlock 2
[ 2.7328 ] StartPage 8
[ 2.7329 ] BCH present 250784
[ 2.7331 ] StartBlock 18
[ 2.7334 ] StartPage 8
[ 2.7352 ]
[ 2.7353 ] Updating smd info
[ 2.7367 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 2.7386 ]
[ 2.7386 ] Updating Odmdata
[ 2.7397 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 2.7409 ]
[ 2.7410 ] Get Signed section of bct
[ 2.7420 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 2.7430 ]
[ 2.7431 ] Signing BCT
[ 2.7449 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 2.7459 ] Assuming zero filled SBK key
[ 2.7461 ]
[ 2.7461 ] Updating BCT with signature
[ 2.7472 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 2.7486 ]
[ 2.7487 ] Generating coldboot mb1-bct
[ 2.7504 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg –
[ 2.7514 ] MB1-BCT version: 0x1
[ 2.7517 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 2.7523 ] Added Platform Config 0 data with size :- 3016
[ 2.7613 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 2.7620 ] Added Platform Config 1 data with size :- 19640
[ 2.7995 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 2.8005 ] Added Platform Config 2 data with size :- 24
[ 2.8010 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg
[ 2.8022 ] Added Platform Config 4 data with size :- 348
[ 2.8030 ]
[ 2.8030 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 2.8030 ] Added Platform Config 3 data with size :- 92
[ 2.8030 ]
[ 2.8030 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 2.8030 ] Added Platform Config 5 data with size :- 56
[ 2.8030 ]
[ 2.8030 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 2.8030 ] Added Platform Config 7 data with size :- 392
[ 2.8030 ]
[ 2.8030 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 2.8030 ] Added Platform Config 8 data with size :- 12
[ 2.8030 ] [ 2.8030 ] Added Platform Config 9 data with size :- 32
[ 2.8030 ]
[ 2.8031 ] Updating mb1-bct with firmware information
[ 2.8044 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.8056 ] MB1-BCT version: 0x1
[ 2.8062 ]
[ 2.8062 ] Updating mb1-bct with storage information
[ 2.8073 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 2.8086 ] MB1-BCT version: 0x1
[ 2.8091 ]
[ 2.8102 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 2.8112 ]
[ 2.8121 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 2.8130 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 2.8141 ]
[ 2.8152 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 2.8161 ] Assuming zero filled SBK key
[ 2.8164 ]
[ 2.8176 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash z
[ 2.8187 ]
[ 2.8187 ] Generating recovery mb1-bct
[ 2.8197 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a040-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device t
[ 2.8205 ] MB1-BCT version: 0x1
[ 2.8209 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 2.8216 ] Added Platform Config 0 data with size :- 3016
[ 2.8236 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 2.8242 ] Added Platform Config 1 data with size :- 19640
[ 2.8407 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 2.8418 ] Added Platform Config 2 data with size :- 24
[ 2.8421 ]
[ 2.8421 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg
[ 2.8421 ] Added Platform Config 4 data with size :- 348
[ 2.8421 ]
[ 2.8421 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 2.8421 ] Added Platform Config 3 data with size :- 92
[ 2.8421 ]
[ 2.8421 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 2.8421 ] Added Platform Config 5 data with size :- 56
[ 2.8421 ]
[ 2.8421 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 2.8421 ] Added Platform Config 7 data with size :- 392
[ 2.8421 ]
[ 2.8421 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 2.8421 ] Added Platform Config 8 data with size :- 12
[ 2.8421 ]
[ 2.8421 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 2.8421 ] Added Platform Config 9 data with size :- 32
[ 2.8421 ]
[ 2.8422 ] Updating mb1-bct with firmware information
[ 2.8433 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 2.8442 ] MB1-BCT version: 0x1
[ 2.8448 ]
[ 2.8449 ] Updating mb1-bct with storage information
[ 2.8459 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 2.8467 ] MB1-BCT version: 0x1
[ 2.8472 ]
[ 2.8483 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 2.8493 ]
[ 2.8503 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 2.8514 ] adding BCH for mb1_bct_MB1.bct
[ 2.8529 ]
[ 2.8544 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 2.8557 ] Assuming zero filled SBK key
[ 2.8561 ]
[ 2.8577 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 2.8591 ]
[ 2.8591 ] Generating coldboot mem-bct
[ 2.8602 ] tegrabct_v2 --chip 0x19 0 --sdram /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1.cfg --membct /home//Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_2.bct /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_3.bct /home/rob
[ 2.8612 ] Packing sdram param for instance[0]
[ 2.8831 ] Packing sdram param for instance[1]
[ 2.8831 ] Packing sdram param for instance[2]
[ 2.8831 ] Packing sdram param for instance[3]
[ 2.8831 ]
[ 2.8831 ] Getting sector size from pt
[ 2.8030 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 2.8842 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 2.8851 ]
[ 2.8853 ] BlockSize read from layout is 200
[ 2.8864 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bo.bct /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_3.bct /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootl
[ 2.8874 ] Binary 1 length is 48352
[ 2.8877 ] Binary 1 align length is 48640
[ 2.8890 ] Binary 2 length is 48352
[ 2.8893 ] Binary 2 align length is 48640
[ 2.8898 ] Binary 3 length is 48352
[ 2.8901 ] Binary 3 align length is 48640
[ 2.8907 ] Binary 4 length is 48352
[ 2.8910 ] Binary 4 align length is 48640
[ 2.8914 ] Buffer length is 194560
[ 2.8914 ] adding BCH for /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_1.bct
[ 2.8914 ] new length is 198656
[ 2.8915 ]
[ 2.8915 ] Generating recovery mem-bct
[ 2.8924 ] tegrabct_v2 --chip 0x19 0 --sdram /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1.cfg --membct /home//Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_2.bct /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_3.bct /home/rob
[ 2.8933 ] Packing sdram param for instance[0]
[ 2.9167 ] Packing sdram param for instance[1]
[ 2.9168 ] Packing sdram param for instance[2]
[ 2.9168 ] Packing sdram param for instance[3]
[ 2.9168 ]
[ 2.9181 ] tegrahost_v2 --chip 0x19 --align /home/robertml/Desktop/xav/Xavier/Linux_for_Tegra/bootloader/16180/tmpL5OToJ1_1.bct
[ 2.9195 ]
[ 2.9205 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader tmpL5OToJ1_1.bct zerosbk
[ 2.9215 ] adding BCH for tmpL5OToJ1_1.bct
[ 2.9240 ]
[ 2.9255 ] tegrasign_v2 --key None --list tmpL5OToJ1_1_sigheader.bct_list.xml
[ 2.9265 ] Assuming zero filled SBK key
[ 2.9268 ]
[ 2.9281 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tmpL5OToJ1_1_sigheader.bct.encrypt tmpL5OToJ1_1_sigheader.bct.hash zerosbk
[ 2.9292 ]
[ 2.9293 ] Copying signatures
[ 2.9301 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 2.9770 ]
[ 2.9770 ] Boot Rom communication
[ 2.9786 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 2.9798 ] BR_CID: 0x88021911645065c21000000018008280
[ 2.9815 ] RCM version 0X190001
[ 2.9818 ] Boot Rom communication completed
[ 3.9987 ]
[ 5.0015 ] tegrarcm_v2 --isapplet
[ 5.0029 ] Applet version 01.00.0000
[ 5.0107 ]
[ 5.0107 ] Sending BCTs
[ 5.0127 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem tmpL5OToJ1
[ 5.0152 ] Applet version 01.00.0000
[ 5.0231 ] Sending bct_bootrom
[ 5.0233 ] […] 100%
[ 5.0292 ] Sending bct_mb1
[ 5.0347 ] […] 100%
[ 5.0434 ] Sending bct_mem
[ 5.1268 ] […] 100%
[ 5.2397 ]
[ 5.2397 ] Generating blob
[ 5.2417 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 5.2432 ]
[ 5.2447 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 5.2461 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 5.2559 ]
[ 5.2577 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml
[ 5.2588 ] Assuming zero filled SBK key
[ 5.2594 ]
[ 5.2611 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_si
[ 5.2626 ]
[ 5.2638 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 5.2847 ]
[ 5.2861 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 5.2876 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 5.2970 ]
[ 5.2989 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml
[ 5.3002 ] Assuming zero filled SBK key
[ 5.3010 ]
[ 5.3030 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.
[ 5.3045 ]
[ 5.3062 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 5.3075 ]
[ 5.3088 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 5.3100 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 5.3104 ]
[ 5.3119 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml
[ 5.3128 ] Assuming zero filled SBK key
[ 5.3134 ]
[ 5.3150 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.
[ 5.3163 ]
[ 5.3175 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 5.3186 ]
[ 5.3199 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 5.3209 ] Header already present for blob_mce_c10_prod_cr.bin
[ 5.3259 ]
[ 5.3275 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml
[ 5.3284 ] Assuming zero filled SBK key
[ 5.3290 ]
[ 5.3307 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zer
[ 5.3326 ]
[ 5.3339 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 5.3351 ]
[ 5.3362 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 5.3374 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 5.4464 ]
[ 5.4483 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml
[ 5.4492 ] Assuming zero filled SBK key
[ 5.4539 ]
[ 5.4557 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zer
[ 5.4616 ]
[ 5.4631 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 5.4641 ]
[ 5.4651 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[ 5.4660 ] adding BCH for blob_bpmp_t194.bin
[ 5.4948 ]
[ 5.4963 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml
[ 5.4971 ] Assuming zero filled SBK key
[ 5.4984 ]
[ 5.5002 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 5.5031 ]
[ 5.5043 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[ 5.5053 ]
[ 5.5062 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[ 5.5072 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[ 5.5209 ]
[ 5.5224 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml
[ 5.5232 ] Assuming zero filled SBK key
[ 5.5240 ]
[ 5.5256 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a0
[ 5.5273 ]
[ 5.5284 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 5.5293 ]
[ 5.5302 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[ 5.5311 ] adding BCH for blob_spe_t194.bin
[ 5.5347 ]
[ 5.5363 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml
[ 5.5372 ] Assuming zero filled SBK key
[ 5.5375 ]
[ 5.5394 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 5.5408 ]
[ 5.5420 ] tegrahost_v2 --chip 0x19 --align blob_tos_t194.img
[ 5.5431 ]
[ 5.5441 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos_t194.img zerosbk
[ 5.5451 ] adding BCH for blob_tos_t194.img
[ 5.5491 ]
[ 5.5507 ] tegrasign_v2 --key None --list blob_tos_t194_sigheader.img_list.xml
[ 5.5518 ] Assuming zero filled SBK key
[ 5.5522 ]
[ 5.5539 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos_t194_sigheader.img.encrypt blob_tos_t194_sigheader.img.hash zerosbk
[ 5.5554 ]
[ 5.5565 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 5.5574 ]
[ 5.5584 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[ 5.5593 ] adding BCH for blob_eks.img
[ 5.5595 ]
[ 5.5612 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 5.5623 ] Assuming zero filled SBK key
[ 5.5625 ]
[ 5.5643 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 5.5658 ]
[ 5.5672 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[ 5.5685 ]
[ 5.5696 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 5.5708 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[ 5.5819 ]
[ 5.5834 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml
[ 5.5843 ] Assuming zero filled SBK key
[ 5.5849 ]
[ 5.5865 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p28
[ 5.5885 ]
[ 5.5900 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 5.5911 ] number of images in blob are 11
[ 5.5916 ] blobsize is 5710472
[ 5.5919 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 229312
[ 5.5954 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 125408
[ 5.5963 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 20400
[ 5.5972 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 234192
[ 5.5981 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3378064
[ 5.5989 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 901712
[ 5.5997 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 361696
[ 5.6008 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95184
[ 5.6016 ] Added binary blob_tos_t194_sigheader.img.encrypt of size 91008
[ 5.6024 ] Added binary blob_eks_sigheader.img.encrypt of size 5184
[ 5.6028 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 268128
[ 5.6028 ]
[ 5.6029 ] Sending bootloader and pre-requisite binaries
[ 5.6040 ] tegrarcm_v2 --download blob blob.bin
[ 5.6049 ] Applet version 01.00.0000
[ 5.6127 ] Sending blob
[ 5.6128 ] […] 100%
[ 6.4215 ]
[ 6.4232 ] tegrarcm_v2 --boot recovery
[ 6.4248 ] Applet version 01.00.0000
[ 6.4404 ]
[ 7.4433 ] tegrarcm_v2 --isapplet
[ 1011.5177 ]
[ 1011.5194 ] tegrarcm_v2 --ismb2
[ 2027.3256 ]
[ 2027.3420 ] tegradevflash_v2 --iscpubl
[ 2027.3435 ] CPU Bootloader is not running on device.
[ 3043.1335 ]
[ 3044.1364 ] tegrarcm_v2 --isapplet
[ 4058.9416 ]
[ 4058.9434 ] tegrarcm_v2 --ismb2
[ 5074.7495 ]
[ 5074.7514 ] tegradevflash_v2 --iscpubl
[ 5074.7532 ] CPU Bootloader is not running on device.
[ 6090.5576 ]
[ 6091.5605 ] tegrarcm_v2 --isapplet
[ 7106.3657 ]
[ 7106.3677 ] tegrarcm_v2 --ismb2
[ 8122.1735 ]
[ 8122.1754 ] tegradevflash_v2 --iscpubl
[ 8122.1768 ] CPU Bootloader is not running on device.
[ 9137.9815 ]
[ 9138.9844 ] tegrarcm_v2 --isapplet
[ 10153.7896 ]
[ 10153.7914 ] tegrarcm_v2 --ismb2
[ 11169.5975 ]
[ 11169.5993 ] tegradevflash_v2 --iscpubl
[ 11169.6007 ] CPU Bootloader is not running on device.
[ 12185.4055 ]
[ 12186.4085 ] tegrarcm_v2 --isapplet
[ 13201.2136 ]
[ 13201.2152 ] tegrarcm_v2 --ismb2
[ 14217.0215 ]
[ 14217.0234 ] tegradevflash_v2 --iscpubl
[ 14217.0249 ] CPU Bootloader is not running on device.
[ 15232.8295 ]
[ 15233.8324 ] tegrarcm_v2 --isapplet
[ 16248.6376 ]
[ 16248.6394 ] tegrarcm_v2 --ismb2
[ 17264.4456 ]
[ 17264.4474 ] tegradevflash_v2 --iscpubl
[ 17264.4489 ] CPU Bootloader is not running on device.
[ 18280.2535 ]
[ 18281.2565 ] tegrarcm_v2 --isapplet
[ 19296.0615 ]
[ 19296.0633 ] tegrarcm_v2 --ismb2
[ 20311.8696 ]
[ 20311.8714 ] tegradevflash_v2 --iscpubl
[ 20311.8731 ] CPU Bootloader is not running on device.
[ 21327.6775 ]
[ 21328.6804 ] tegrarcm_v2 --isapplet
[ 22343.4856 ]
[ 22343.4875 ] tegrarcm_v2 --ismb2
[ 23359.2936 ]
[ 23359.2954 ] tegradevflash_v2 --iscpubl
[ 23359.2970 ] CPU Bootloader is not running on device.
[ 24375.1014 ]
[ 24376.1046 ] tegrarcm_v2 --isapplet
[ 25390.9096 ]
[ 25390.9118 ] tegrarcm_v2 --ismb2
[ 26406.7175 ]
[ 26406.7194 ] tegradevflash_v2 --iscpubl
[ 26406.7209 ] CPU Bootloader is not running on device.
[ 27422.5256 ]
[ 27423.5284 ] tegrarcm_v2 --isapplet
[ 28438.3337 ]
[ 28438.3355 ] tegrarcm_v2 --ismb2
[ 29454.1415 ]
[ 29454.1434 ] tegradevflash_v2 --iscpubl
[ 29454.1452 ] CPU Bootloader is not running on device.
[ 30469.9495 ]
[ 30470.9524 ] tegrarcm_v2 --isapplet
[ 31485.7576 ]
[ 31485.7594 ] tegrarcm_v2 --ismb2
[ 32501.5658 ]
[ 32501.5676 ] tegradevflash_v2 --iscpubl
[ 32501.5690 ] CPU Bootloader is not running on device.
[ 33517.3735 ]
[ 33518.3766 ] tegrarcm_v2 --isapplet
[ 34533.1815 ]
[ 34533.1834 ] tegrarcm_v2 --ismb2
[ 35548.9896 ]
[ 35548.9916 ] tegradevflash_v2 --iscpubl
[ 35548.9930 ] CPU Bootloader is not running on device.
[ 36564.7975 ]
[ 36565.8004 ] tegrarcm_v2 --isapplet
[ 37580.6055 ]
[ 37580.6073 ] tegrarcm_v2 --ismb2
[ 38596.4136 ]
[ 38596.4155 ] tegradevflash_v2 --iscpubl
[ 38596.4170 ] CPU Bootloader is not running on device.
[ 39612.2215 ]
[ 39613.2244 ] tegrarcm_v2 --isapplet
[ 40628.0295 ]
[ 40628.0313 ] tegrarcm_v2 --ismb2
[ 41643.8376 ]
[ 41643.8394 ] tegradevflash_v2 --iscpubl
[ 41643.8412 ] CPU Bootloader is not running on device.
[ 42659.6454 ]
[ 42660.6483 ] tegrarcm_v2 --isapplet
[ 43675.4536 ]
[ 43675.4554 ] tegrarcm_v2 --ismb2
[ 44691.2616 ]
[ 44691.2632 ] tegradevflash_v2 --iscpubl
[ 44691.2648 ] CPU Bootloader is not running on device.
[ 45707.0694 ]
[ 45708.0723 ] tegrarcm_v2 --isapplet
[ 46722.8776 ]
[ 46722.8794 ] tegrarcm_v2 --ismb2
[ 47738.6857 ]
[ 47738.6875 ] tegradevflash_v2 --iscpubl
[ 47738.6891 ] CPU Bootloader is not running on device.
[ 48754.4935 ]
[ 48755.4964 ] tegrarcm_v2 --isapplet
[ 49770.3016 ]
[ 49770.3034 ] tegrarcm_v2 --ismb2
[ 50786.1096 ]
[ 50786.1115 ] tegradevflash_v2 --iscpubl
[ 50786.1132 ] CPU Bootloader is not running on device.
[ 51801.9175 ]
[ 51802.9205 ] tegrarcm_v2 --isapplet
[ 52817.7255 ]
[ 52817.7274 ] tegrarcm_v2 --ismb2
[ 53833.5335 ]
[ 53833.5354 ] tegradevflash_v2 --iscpubl
[ 53833.5368 ] CPU Bootloader is not running on device.
[ 54849.3415 ]
[ 54850.3444 ] tegrarcm_v2 --isapplet
[ 55865.1495 ]
[ 55865.1514 ] tegrarcm_v2 --ismb2
[ 56880.9577 ]
[ 56880.9595 ] tegradevflash_v2 --iscpubl
[ 56880.9612 ] CPU Bootloader is not running on device.
[ 57896.7655 ]
[ 57897.7685 ] tegrarcm_v2 --isapplet
[ 58912.5736 ]
[ 58912.5755 ] tegrarcm_v2 --ismb2
[ 59928.3816 ]
[ 59928.3833 ] tegradevflash_v2 --iscpubl
[ 59928.3849 ] CPU Bootloader is not running on device.
[ 60944.1894 ]
[ 60945.1924 ] tegrarcm_v2 --isapplet
[ 61960.0252 ]
[ 61960.0650 ] tegrarcm_v2 --ismb2
[ 62975.8056 ]
[ 62975.8254 ] tegradevflash_v2 --iscpubl
[ 62975.8270 ] CPU Bootloader is not running on device.
[ 63991.6134 ]
[ 63992.6165 ] tegrarcm_v2 --isapplet
[ 65007.4216 ]
[ 65007.4234 ] tegrarcm_v2 --ismb2
[ 66023.2296 ]
[ 66023.2314 ] tegradevflash_v2 --iscpubl
[ 66023.2328 ] CPU Bootloader is not running on device.
[ 67039.0374 ]
[ 67040.0403 ] tegrarcm_v2 --isapplet
[ 68054.8456 ]
[ 68054.8474 ] tegrarcm_v2 --ismb2
[ 69070.6535 ]
[ 69070.6553 ] tegradevflash_v2 --iscpubl
[ 69070.6568 ] CPU Bootloader is not running on device.
[ 70086.4616 ]
[ 70087.4646 ] tegrarcm_v2 --isapplet
[ 71102.2696 ]
[ 71102.2714 ] tegrarcm_v2 --ismb2
[ 72118.0775 ]
[ 72118.0793 ] tegradevflash_v2 --iscpubl
[ 72118.0808 ] CPU Bootloader is not running on device.
[ 73133.8855 ]
[ 73134.8885 ] tegrarcm_v2 --isapplet
[ 74149.6935 ]
[ 74149.6958 ] tegrarcm_v2 --ismb2
[ 75165.5016 ]
[ 75165.5034 ] tegradevflash_v2 --iscpubl
[ 75165.5049 ] CPU Bootloader is not running on device.
Failed to flash device. Check /home/desktop/xavier/_installer/logs/Xavier/flash_os_galen.log for more details. Please close this terminal window, fix the issue mentioned in log, and run Jetpack again to reinstall.
You can attach a file to an existing post…hover the mouse over the quote mark in the upper right, note a paper clip icon shows up…then click the paper clip. You can then attach this (if needed, then rename to flash_os_galen.txt):
Similar issue here! I use a 18.04 VM though… Have anyone gotten any further?
Hi kelvinsundli,
Please submit RMA request to replace you CVM board.
https://developer.nvidia.com/embedded/faq
I am hitting the same exact issue ? appreciate any help
Just received my jetson xavier today.
lahorite,
Please do not use VM as host.
I’m getting the same issue with jetpack 4.1 (On ubuntu 18, not in a VM, jetpack 4.2 also runs into errors). Has anyone figured out a workaround?
Hi daweim0,
Please file a new topic for it ans paste your log.
