SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_AGX_Xavier_modules_2023-05-17_12-05-30.zip (150.4 KB)
Hi, I am facing issues in installing and setting up a new Jetson AGX Xavier with 64GB SD card. Can anyone help me with what went wrong? I have attached the logs with this.
is your device now able to boot up? It’s not quite clear to allocate the error.
Can you try again with the command way of installing?
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/IN/QuickStart.html
it’s the log when the device was booting up, right?
Can you also give the log when flashing using the command way?
[ 1.3795 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 1.3797 ] File read failed
[ 1.3798 ] Added Platform Config 4 data with size :- 348
[ 1.3799 ]
[ 1.3799 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 1.3799 ] Added Platform Config 3 data with size :- 92
[ 1.3799 ]
[ 1.3799 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 1.3799 ] Added Platform Config 5 data with size :- 68
[ 1.3799 ]
[ 1.3799 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 1.3799 ] Added Platform Config 7 data with size :- 392
[ 1.3799 ]
[ 1.3799 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 1.3799 ] Added Platform Config 8 data with size :- 12
[ 1.3799 ]
[ 1.3799 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 1.3799 ] Added Platform Config 9 data with size :- 32
[ 1.3799 ]
[ 1.3800 ] Updating mb1-bct with firmware information
[ 1.3822 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 1.3834 ] Updating mb1-bct with storage information
[ 1.3853 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.3865 ] Updating mb1-bct with ratchet information
[ 1.3884 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[ 1.3893 ] FwIndex: 1, MinRatchetLevel: 0
[ 1.3898 ] FwIndex: 2, MinRatchetLevel: 0
[ 1.3898 ] FwIndex: 3, MinRatchetLevel: 0
[ 1.3898 ] FwIndex: 4, MinRatchetLevel: 0
[ 1.3898 ] FwIndex: 5, MinRatchetLevel: 0
[ 1.3898 ] FwIndex: 6, MinRatchetLevel: 0
[ 1.3898 ] FwIndex: 7, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 11, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 12, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 13, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 14, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 15, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 16, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 17, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 18, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 19, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 30, MinRatchetLevel: 0
[ 1.3899 ] FwIndex: 31, MinRatchetLevel: 0
[ 1.3899 ]
[ 1.3927 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[ 1.3971 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 1.3986 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 1.4186 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.4189 ] Assuming zero filled SBK key
[ 1.4215 ] Warning: pub_key.key is not found
[ 1.4086 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 1.4099 ] Generating coldboot mem-bct
[ 1.4119 ] tegrabct_v2 --chip 0x19 0 --sdram /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1.cfg --membct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_1.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_2.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_3.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_4.bct
[ 1.4126 ] Packing sdram param for instance[0]
[ 1.4684 ] Packing sdram param for instance[1]
[ 1.4684 ] Packing sdram param for instance[2]
[ 1.4685 ] Packing sdram param for instance[3]
[ 1.4686 ] Packing sdram param for instance[4]
[ 1.4687 ] Packing sdram param for instance[5]
[ 1.4687 ] Packing sdram param for instance[6]
[ 1.4687 ] Packing sdram param for instance[7]
[ 1.4687 ] Packing sdram param for instance[8]
[ 1.4687 ] Packing sdram param for instance[9]
[ 1.4687 ] Packing sdram param for instance[10]
[ 1.4687 ] Packing sdram param for instance[11]
[ 1.4687 ] Packing sdram param for instance[12]
[ 1.4687 ] Packing sdram param for instance[13]
[ 1.4687 ] Packing sdram param for instance[14]
[ 1.4687 ] Packing sdram param for instance[15]
[ 1.4687 ]
[ 1.4687 ] Getting sector size from pt
[ 1.4709 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 1.4720 ] BlockSize read from layout is 200
[ 1.4741 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_1.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_2.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_3.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_4.bct
[ 1.4748 ] adding BCH for /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_1.bct
[ 1.4824 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 1.4864 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 1.4877 ] Header already present for mem_coldboot_aligned.bct
[ 1.5069 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.5072 ] Assuming zero filled SBK key
[ 1.5105 ] Warning: pub_key.key is not found
[ 1.4979 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 1.5005 ] Generating recovery mem-bct
[ 1.5030 ] tegrabct_v2 --chip 0x19 0 --sdram /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1.cfg --membct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_1.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_2.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_3.bct /home/owner/Downloads/Linux_for_Tegra/bootloader/39995/tmpmp5lmd3n1_4.bct
[ 1.5043 ] Packing sdram param for instance[0]
[ 1.5690 ] Packing sdram param for instance[1]
[ 1.5691 ] Packing sdram param for instance[2]
[ 1.5692 ] Packing sdram param for instance[3]
[ 1.5694 ] Packing sdram param for instance[4]
[ 1.5694 ] Packing sdram param for instance[5]
[ 1.5694 ] Packing sdram param for instance[6]
[ 1.5694 ] Packing sdram param for instance[7]
[ 1.5694 ] Packing sdram param for instance[8]
[ 1.5694 ] Packing sdram param for instance[9]
[ 1.5694 ] Packing sdram param for instance[10]
[ 1.5694 ] Packing sdram param for instance[11]
[ 1.5694 ] Packing sdram param for instance[12]
[ 1.5694 ] Packing sdram param for instance[13]
[ 1.5694 ] Packing sdram param for instance[14]
[ 1.5694 ] Packing sdram param for instance[15]
[ 1.5694 ]
[ 1.5725 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[ 1.5757 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 1.5765 ] adding BCH for mem_rcm_aligned.bct
[ 1.5952 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.5954 ] Assuming zero filled SBK key
[ 1.5966 ] Warning: pub_key.key is not found
[ 1.5829 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 1.5852 ] Copying signatures
[ 1.5874 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.7888 ] Boot Rom communication
[ 1.7910 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 1.7919 ] BR_CID: 0x88021911647d7785200000000c000040
[ 1.8451 ] RCM version 0X190001
[ 1.9008 ] Boot Rom communication completed
[ 3.9183 ] tegrarcm_v2 --isapplet
[ 3.9194 ] Applet version 01.00.0000
[ 4.0338 ] Sending BCTs
[ 4.0361 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 4.0368 ] Applet version 01.00.0000
[ 4.1537 ] Sending bct_bootrom
[ 4.1538 ] [................................................] 100%
[ 4.1547 ] Sending bct_mb1
[ 4.1595 ] [................................................] 100%
[ 4.1628 ] Sending bct_mem
[ 4.2071 ] [................................................] 100%
[ 4.2491 ] Generating blob
[ 4.2514 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 4.2539 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194_aligned.bin zerosbk
[ 4.2544 ] adding BCH for blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 4.2765 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.2766 ] Assuming zero filled SBK key
[ 4.2781 ] Warning: pub_key.key is not found
[ 4.2643 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.hash zerosbk
[ 4.2697 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194_aligned.bin
[ 4.2720 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194_aligned.bin zerosbk
[ 4.2728 ] adding BCH for blob_nvtboot_recovery_t194_aligned.bin
[ 4.2938 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.2939 ] Assuming zero filled SBK key
[ 4.2957 ] Warning: pub_key.key is not found
[ 4.2831 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_t194_aligned_sigheader.bin.hash zerosbk
[ 4.2887 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr_aligned.bin
[ 4.2911 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
[ 4.2917 ] Header already present for blob_preboot_c10_prod_cr_aligned.bin
[ 4.3096 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.3098 ] Assuming zero filled SBK key
[ 4.3113 ] Warning: pub_key.key is not found
[ 4.2976 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_aligned_sigheader.bin.encrypt blob_preboot_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 4.3005 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr_aligned.bin
[ 4.3028 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr_aligned.bin zerosbk
[ 4.3036 ] Header already present for blob_mce_c10_prod_cr_aligned.bin
[ 4.3236 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.3238 ] Assuming zero filled SBK key
[ 4.3254 ] Warning: pub_key.key is not found
[ 4.3117 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mce_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 4.3174 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr_aligned.bin
[ 4.3197 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
[ 4.3202 ] adding BCH for blob_mts_c10_prod_cr_aligned.bin
[ 4.3934 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.3936 ] Assuming zero filled SBK key
[ 4.4000 ] Warning: pub_key.key is not found
[ 4.3867 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mts_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 4.4206 ] tegrahost_v2 --chip 0x19 --align blob_bpmp-2_t194_aligned.bin
[ 4.4230 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
[ 4.4236 ] adding BCH for blob_bpmp-2_t194_aligned.bin
[ 4.4590 ] tegrasign_v3.py --key None --list blob_bpmp-2_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.4593 ] Assuming zero filled SBK key
[ 4.4625 ] Warning: pub_key.key is not found
[ 4.4487 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp-2_t194_aligned_sigheader.bin.encrypt blob_bpmp-2_t194_aligned_sigheader.bin.hash zerosbk
[ 4.4675 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 4.4704 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb zerosbk
[ 4.4711 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[ 4.4910 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 4.4912 ] Assuming zero filled SBK key
[ 4.4930 ] Warning: pub_key.key is not found
[ 4.4797 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_lz4_aligned_sigheader.dtb.hash zerosbk
[ 4.4857 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194_aligned.bin
[ 4.4884 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194_aligned.bin zerosbk
[ 4.4889 ] adding BCH for blob_spe_t194_aligned.bin
[ 4.5082 ] tegrasign_v3.py --key None --list blob_spe_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.5083 ] Assuming zero filled SBK key
[ 4.5097 ] Warning: pub_key.key is not found
[ 4.4959 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_aligned_sigheader.bin.encrypt blob_spe_t194_aligned_sigheader.bin.hash zerosbk
[ 4.5007 ] tegrahost_v2 --chip 0x19 --align blob_tos-optee_t194_aligned.img
[ 4.5035 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t194_aligned.img zerosbk
[ 4.5044 ] adding BCH for blob_tos-optee_t194_aligned.img
[ 4.5428 ] tegrasign_v3.py --key None --list blob_tos-optee_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 4.5430 ] Assuming zero filled SBK key
[ 4.5454 ] Warning: pub_key.key is not found
[ 4.5317 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-optee_t194_aligned_sigheader.img.encrypt blob_tos-optee_t194_aligned_sigheader.img.hash zerosbk
[ 4.5461 ] tegrahost_v2 --chip 0x19 --align blob_eks_t194_aligned.img
[ 4.5484 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t194_aligned.img zerosbk
[ 4.5495 ] adding BCH for blob_eks_t194_aligned.img
[ 4.5683 ] tegrasign_v3.py --key None --list blob_eks_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 4.5684 ] Assuming zero filled SBK key
[ 4.5695 ] Warning: pub_key.key is not found
[ 4.5556 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_t194_aligned_sigheader.img.encrypt blob_eks_t194_aligned_sigheader.img.hash zerosbk
[ 4.5583 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 4.5606 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000_aligned.dtb zerosbk
[ 4.5614 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000_aligned.dtb
[ 4.5893 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 4.5895 ] Assuming zero filled SBK key
[ 4.5913 ] Warning: pub_key.key is not found
[ 4.5776 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_aligned_sigheader.dtb.hash zerosbk
[ 4.5868 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 4.5876 ] number of images in blob are 11
[ 4.5878 ] blobsize is 6639704
[ 4.5879 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 233040
[ 4.5901 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[ 4.5903 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 4.5904 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[ 4.5906 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[ 4.5922 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[ 4.5933 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt of size 90608
[ 4.5935 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[ 4.5936 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 914992
[ 4.5939 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
[ 4.5940 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 487488
[ 4.5976 ] Sending bootloader and pre-requisite binaries
[ 4.5996 ] tegrarcm_v2 --download blob blob.bin
[ 4.6001 ] Applet version 01.00.0000
[ 4.7146 ] Sending blob
[ 4.7147 ] [................................................] 100%
[ 5.6282 ] tegrarcm_v2 --boot recovery
[ 5.6298 ] Applet version 01.00.0000
[ 6.7503 ] tegrarcm_v2 --isapplet
[ 7.8924 ] tegrarcm_v2 --ismb2
[ 8.0154 ] tegradevflash_v2 --iscpubl
[ 8.0174 ] Bootloader version 01.00.0000
[ 8.0742 ] Bootloader version 01.00.0000
[ 8.0752 ] Retrieving storage infomation
[ 8.0789 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 8.0809 ] Applet is not running on device. Continue with Bootloader
[ 8.1972 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 8.1981 ] Bootloader version 01.00.0000
[ 8.2621 ] Saved platform info in storage_info.bin
[ 8.2636 ] Flashing the device
[ 8.2670 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 8.2686 ] gpt_secondary_0_3.bin:
[ 8.2690 ] partition_id partition_name StartingLba EndingLba
[ 8.2694 ] 1 BCT 0 63
[ 8.2698 ] 2 mb1 64 575
[ 8.2701 ] 3 mb1_b 576 1087
[ 8.2705 ] 4 MB1_BCT 1088 1215
[ 8.2709 ] 5 MEM_BCT 1216 1663
[ 8.2712 ] 6 spe-fw 1664 2175
[ 8.2716 ] 7 mb2 2176 2623
[ 8.2720 ] 8 mts-preboot 2624 2687
[ 8.2724 ] 9 reserved_for_chain_A_boot 2688 6783
[ 8.2728 ] 10 MB1_BCT_b 6784 6911
[ 8.2732 ] 11 MEM_BCT_b 6912 7359
[ 8.2736 ] 12 spe-fw_b 7360 7871
[ 8.2738 ] 13 mb2_b 7872 8319
[ 8.2738 ] 14 mts-preboot_b 8320 8383
[ 8.2738 ] 15 reserved_for_chain_B_boot 8384 12479
[ 8.2738 ] 16 BCT-boot-chain_backup 15616 15743
[ 8.2738 ] 17 reserved_partition 15744 15871
[ 8.2738 ] 18 secondary_gpt_backup 15872 15999
[ 8.2738 ] 19 VER_b 16000 16127
[ 8.2739 ] 20 VER 16128 16255
[ 8.2739 ] gpt_primary_1_3.bin:
[ 8.2739 ] partition_id partition_name StartingLba EndingLba
[ 8.2739 ] 1 APP 40 58720295
[ 8.2739 ] 2 mts-mce 58720296 58720615
[ 8.2739 ] 3 mts-proper 58720616 58728807
[ 8.2739 ] 4 cpu-bootloader 58728808 58736999
[ 8.2739 ] 5 bootloader-dtb 58737000 58738023
[ 8.2739 ] 6 secure-os 58738024 58743143
[ 8.2739 ] 7 eks 58743144 58743271
[ 8.2739 ] 8 bpmp-fw 58743272 58746343
[ 8.2739 ] 9 bpmp-fw-dtb 58746344 58748391
[ 8.2739 ] 10 xusb-fw 58748392 58748711
[ 8.2739 ] 11 rce-fw 58748712 58752807
[ 8.2740 ] 12 adsp-fw 58752808 58756903
[ 8.2740 ] 13 sce-fw 58756904 58758951
[ 8.2740 ] 14 sc7 58758952 58759207
[ 8.2740 ] 15 kernel 58759208 58923047
[ 8.2740 ] 16 kernel-dtb 58923048 58924071
[ 8.2740 ] 17 reserved_for_chain_A_user 58924072 58989607
[ 8.2740 ] 18 mts-mce_b 58990592 58990911
[ 8.2740 ] 19 mts-proper_b 58990912 58999103
[ 8.2740 ] 20 cpu-bootloader_b 58999104 59007295
[ 8.2741 ] 21 bootloader-dtb_b 59007296 59008319
[ 8.2741 ] 22 secure-os_b 59008320 59013439
[ 8.2741 ] 23 eks_b 59013440 59013567
[ 8.2741 ] 24 bpmp-fw_b 59013568 59016639
[ 8.2741 ] 25 bpmp-fw-dtb_b 59016640 59018687
[ 8.2741 ] 26 xusb-fw_b 59018688 59019007
[ 8.2741 ] 27 rce-fw_b 59019008 59023103
[ 8.2741 ] 28 adsp-fw_b 59023104 59027199
[ 8.2742 ] 29 sce-fw_b 59027200 59029247
[ 8.2742 ] 30 sc7_b 59029248 59029503
[ 8.2742 ] 31 kernel_b 59029504 59193343
[ 8.2742 ] 32 kernel-dtb_b 59193344 59194367
[ 8.2742 ] 33 reserved_for_chain_B_user 59194368 59260927
[ 8.2742 ] 34 recovery 59260928 59424767
[ 8.2742 ] 35 recovery-dtb 59424768 59425791
[ 8.2742 ] 36 RP1 59425792 59442175
[ 8.2742 ] 37 RP2 59442176 59458559
[ 8.2743 ] 38 RECROOTFS 59458560 60072959
[ 8.2743 ] 39 uefi_variables 60072960 60073215
[ 8.2743 ] 40 esp 60073216 60204287
[ 8.2743 ] 41 recovery_alt 60204288 60368127
[ 8.2743 ] 42 recovery-dtb_alt 60368128 60369151
[ 8.2743 ] 43 esp_alt 60369152 60500223
[ 8.2743 ] 44 UDA 60500224 61079518
[ 8.2743 ] gpt_secondary_1_3.bin:
[ 8.2743 ] partition_id partition_name StartingLba EndingLba
[ 8.2743 ] 1 APP 40 58720295
[ 8.2743 ] 2 mts-mce 58720296 58720615
[ 8.2743 ] 3 mts-proper 58720616 58728807
[ 8.2743 ] 4 cpu-bootloader 58728808 58736999
[ 8.2744 ] 5 bootloader-dtb 58737000 58738023
[ 8.2744 ] 6 secure-os 58738024 58743143
[ 8.2744 ] 7 eks 58743144 58743271
[ 8.2744 ] 8 bpmp-fw 58743272 58746343
[ 8.2744 ] 9 bpmp-fw-dtb 58746344 58748391
[ 8.2744 ] 10 xusb-fw 58748392 58748711
[ 8.2744 ] 11 rce-fw 58748712 58752807
[ 8.2744 ] 12 adsp-fw 58752808 58756903
[ 8.2744 ] 13 sce-fw 58756904 58758951
[ 8.2744 ] 14 sc7 58758952 58759207
[ 8.2744 ] 15 kernel 58759208 58923047
[ 8.2744 ] 16 kernel-dtb 58923048 58924071
[ 8.2744 ] 17 reserved_for_chain_A_user 58924072 58989607
[ 8.2744 ] 18 mts-mce_b 58990592 58990911
[ 8.2744 ] 19 mts-proper_b 58990912 58999103
[ 8.2744 ] 20 cpu-bootloader_b 58999104 59007295
[ 8.2745 ] 21 bootloader-dtb_b 59007296 59008319
[ 8.2745 ] 22 secure-os_b 59008320 59013439
[ 8.2745 ] 23 eks_b 59013440 59013567
[ 8.2745 ] 24 bpmp-fw_b 59013568 59016639
[ 8.2745 ] 25 bpmp-fw-dtb_b 59016640 59018687
[ 8.2745 ] 26 xusb-fw_b 59018688 59019007
[ 8.2745 ] 27 rce-fw_b 59019008 59023103
[ 8.2745 ] 28 adsp-fw_b 59023104 59027199
[ 8.2745 ] 29 sce-fw_b 59027200 59029247
[ 8.2745 ] 30 sc7_b 59029248 59029503
[ 8.2745 ] 31 kernel_b 59029504 59193343
[ 8.2745 ] 32 kernel-dtb_b 59193344 59194367
[ 8.2745 ] 33 reserved_for_chain_B_user 59194368 59260927
[ 8.2745 ] 34 recovery 59260928 59424767
[ 8.2745 ] 35 recovery-dtb 59424768 59425791
[ 8.2745 ] 36 RP1 59425792 59442175
[ 8.2745 ] 37 RP2 59442176 59458559
[ 8.2746 ] 38 RECROOTFS 59458560 60072959
[ 8.2746 ] 39 uefi_variables 60072960 60073215
[ 8.2746 ] 40 esp 60073216 60204287
[ 8.2746 ] 41 recovery_alt 60204288 60368127
[ 8.2746 ] 42 recovery-dtb_alt 60368128 60369151
[ 8.2746 ] 43 esp_alt 60369152 60500223
[ 8.2746 ] 44 UDA 60500224 61079518
[ 8.2746 ]
[ 8.2746 ] Start flashing
[ 8.2777 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 8.2784 ] Bootloader version 01.00.0000
[ 8.3339 ] Erasing sdmmc_boot: 3 ......... [Done]
[ 9.4408 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin [ 16896 bytes ]
[ 9.4410 ] [................................................] 100%
[ 9.4736 ] Erasing sdmmc_user: 3 ......... [Done]
[ 10.0875 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 10.0877 ] [................................................] 100%
[ 10.0887 ] Writing partition primary_gpt with gpt_primary_1_3.bin [ 16896 bytes ]
[ 10.0957 ] [................................................] 100%
[ 10.0970 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin [ 16896 bytes ]
[ 10.1165 ] [................................................] 100%
[ 10.1367 ] Writing partition mb1 with mb1_t194_prod_aligned_sigheader.bin.encrypt [ 249008 bytes ]
[ 10.1371 ] [................................................] 100%
[ 10.1457 ] Writing partition mb1_b with mb1_b_t194_prod_aligned_sigheader.bin.encrypt [ 249008 bytes ]
[ 10.2538 ] [................................................] 100%
[ 10.2624 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt [ 95232 bytes ]
[ 10.2879 ] [................................................] 100%
[ 10.2916 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt [ 207584 bytes ]
[ 10.2997 ] [................................................] 100%
[ 10.3064 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt [ 24016 bytes ]
[ 10.3309 ] [................................................] 100%
[ 10.3321 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt [ 95232 bytes ]
[ 10.3512 ] [................................................] 100%
[ 10.3545 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt [ 207584 bytes ]
[ 10.4431 ] [................................................] 100%
[ 10.4498 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt [ 24016 bytes ]
[ 10.4744 ] [................................................] 100%
[ 10.4757 ] Writing partition VER_b with emmc_bootblob_ver.txt [ 101 bytes ]
[ 10.4947 ] [................................................] 100%
[ 10.4969 ] Writing partition VER with emmc_bootblob_ver.txt [ 101 bytes ]
[ 10.5875 ] [................................................] 100%
[ 10.5884 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 10.6011 ] [................................................] 100%
[ 10.6019 ] Writing partition APP with system.img [ 5707436452 bytes ]
[ 10.6091 ] [................................................] 100%
[ 252.0164 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt [ 145184 bytes ]
[ 252.0260 ] [................................................] 100%
[ 252.0301 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt [ 3430416 bytes ]
[ 252.0480 ] [................................................] 100%
[ 252.1884 ] Writing partition cpu-bootloader with nvdisp-init_sigheader.bin.encrypt [ 3215360 bytes ]
[ 252.2101 ] [................................................] 100%
[ 252.3320 ] Writing partition bootloader-dtb with tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt [ 487488 bytes ]
[ 252.3404 ] [................................................] 100%
[ 252.3517 ] Writing partition secure-os with tos-optee_t194_sigheader.img.encrypt [ 914992 bytes ]
[ 252.3745 ] [................................................] 100%
[ 252.3986 ] Writing partition eks with eks_t194_sigheader.img.encrypt [ 5136 bytes ]
[ 252.4245 ] [................................................] 100%
[ 252.4258 ] Writing partition bpmp-fw with bpmp-2_t194_sigheader.bin.encrypt [ 1007392 bytes ]
[ 252.4445 ] [................................................] 100%
[ 252.4706 ] Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt [ 90608 bytes ]
[ 252.4968 ] [................................................] 100%
[ 252.4983 ] Writing partition xusb-fw with xusb_sil_rel_fw [ 129024 bytes ]
[ 252.5172 ] [................................................] 100%
[ 252.5217 ] Writing partition rce-fw with camera-rtcpu-t194-rce_sigheader.img.encrypt [ 529776 bytes ]
[ 252.5295 ] [................................................] 100%
[ 252.5429 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt [ 396864 bytes ]
[ 252.5660 ] [................................................] 100%
[ 252.5771 ] Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt [ 55264 bytes ]
[ 252.5976 ] [................................................] 100%
[ 252.5985 ] Writing partition kernel with boot.img [ 43065344 bytes ]
[ 252.6174 ] [................................................] 100%
[ 254.2674 ] Writing partition kernel-dtb with kernel_tegra194-p2888-0001-p2822-0000.dtb [ 393880 bytes ]
[ 254.2740 ] [................................................] 100%
[ 254.2845 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt [ 145184 bytes ]
[ 254.3063 ] [................................................] 100%
[ 254.3091 ] Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt [ 3430416 bytes ]
[ 254.3297 ] [................................................] 100%
[ 254.4548 ] Writing partition cpu-bootloader_b with nvdisp-init_sigheader.bin.encrypt [ 3215360 bytes ]
[ 254.4754 ] [................................................] 100%
[ 254.5972 ] Writing partition bootloader-dtb_b with tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt [ 487488 bytes ]
[ 254.6056 ] [................................................] 100%
[ 254.6173 ] Writing partition secure-os_b with tos-optee_t194_sigheader.img.encrypt [ 914992 bytes ]
[ 254.6404 ] [................................................] 100%
[ 254.6641 ] Writing partition eks_b with eks_t194_sigheader.img.encrypt [ 5136 bytes ]
[ 254.6885 ] [................................................] 100%
[ 254.6892 ] Writing partition bpmp-fw_b with bpmp-2_t194_sigheader.bin.encrypt [ 1007392 bytes ]
[ 254.7074 ] [................................................] 100%
[ 254.7365 ] Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p2888-a04_lz4_sigheader.dtb.encrypt [ 90608 bytes ]
[ 254.7631 ] [................................................] 100%
[ 254.7646 ] Writing partition xusb-fw_b with xusb_sil_rel_fw [ 129024 bytes ]
[ 254.7845 ] [................................................] 100%
[ 254.7874 ] Writing partition rce-fw_b with camera-rtcpu-t194-rce_sigheader.img.encrypt [ 529776 bytes ]
[ 254.7945 ] [................................................] 100%
[ 254.8087 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt [ 396864 bytes ]
[ 254.8309 ] [................................................] 100%
[ 254.8403 ] Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt [ 55264 bytes ]
[ 254.8723 ] [................................................] 100%
[ 254.8741 ] Writing partition kernel_b with boot.img [ 43065344 bytes ]
[ 254.8926 ] [................................................] 100%
[ 256.5383 ] Writing partition kernel-dtb_b with kernel_tegra194-p2888-0001-p2822-0000.dtb [ 393880 bytes ]
[ 256.5471 ] [................................................] 100%
[ 256.5567 ] Writing partition recovery with recovery.img [ 46712832 bytes ]
[ 256.5782 ] [................................................] 100%
[ 258.3770 ] Writing partition recovery-dtb with tegra194-p2888-0001-p2822-0000.dtb.rec [ 393880 bytes ]
[ 258.3877 ] [................................................] 100%
[ 258.3970 ] Writing partition esp with esp.img [ 67108864 bytes ]
[ 258.4192 ] [................................................] 100%
[ 260.9790 ] tegradevflash_v2 --write secondary_gpt_backup gpt_secondary_0_3.bin
[ 260.9807 ] Bootloader version 01.00.0000
[ 261.0379 ] Writing partition secondary_gpt_backup with gpt_secondary_0_3.bin [ 16896 bytes ]
[ 261.0384 ] [................................................] 100%
[ 261.0496 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 261.0506 ] Bootloader version 01.00.0000
[ 261.1055 ] Writing partition BCT with br_bct_BR.bct [ 2888 bytes ]
[ 261.1056 ] [................................................] 100%
[ 261.2474 ] tegradevflash_v2 --write BCT-boot-chain_backup bct_backup.img
[ 261.2481 ] Bootloader version 01.00.0000
[ 261.3056 ] Writing partition BCT-boot-chain_backup with bct_backup.img [ 32768 bytes ]
[ 261.3057 ] [................................................] 100%
[ 261.3168 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 261.3180 ] Bootloader version 01.00.0000
[ 261.3736 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 31024 bytes ]
[ 261.3739 ] [................................................] 100%
[ 261.3962 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 261.3970 ] Bootloader version 01.00.0000
[ 261.4536 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 31024 bytes ]
[ 261.4539 ] [................................................] 100%
[ 261.5561 ] tegradevflash_v2 --write MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 261.5570 ] Bootloader version 01.00.0000
[ 261.6175 ] Writing partition MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 198656 bytes ]
[ 261.6177 ] [................................................] 100%
[ 261.7176 ] tegradevflash_v2 --write MEM_BCT_b mem_coldboot_sigheader.bct.encrypt
[ 261.7186 ] Bootloader version 01.00.0000
[ 261.7736 ] Writing partition MEM_BCT_b with mem_coldboot_sigheader.bct.encrypt [ 198656 bytes ]
[ 261.7738 ] [................................................] 100%
[ 261.7916 ] Flashing completed
[ 261.7917 ] Coldbooting the device
[ 261.7937 ] tegrarcm_v2 --ismb2
[ 261.9116 ] tegradevflash_v2 --reboot coldboot
[ 261.9123 ] Bootloader version 01.00.0000
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
I was able to get this much from the terminal, there was a it more before this. Hope this helps.
During booting it shows there was a failure while configuring USB flashing port for device mode. What else can I try?
Sorry that I did not make it clear in the previous reply. I need you to provide the UART log when you boot up the device, not the flashing log.
Looks like the flashing process ended successfully, but something happened during booting to cause it to halt.
Hello, I am new at this, can you guide me on how can I get it? Is it the same as the image I have attached above?
you need to plug in the micro USB port on the front of your AGX Xavier and connect it to your host PC, and you will find some ttyUSBx devices available under /dev/ on your host.
Open up connections with 115200 baud rate using tools like picocom,
(sudo picocom -b 115200 /dev/ttyUSB3), then power up your device.
Usually it’s ttyUSB3 for AGX Xavier, but if nothing shows up, try other ttyUSBx devices.
Copy everything showing up in the console, paste it into a text file, and put the file here.
Check your host side dmesg after you connect the micro usb port. Check if any error there to make you not able to see /dev/ttyUSBx.
Just want to clarify. We are checking your uart port. Serial console port. Which is made like a micro usb port on AGX Xavier devkit.
We are not talking about custom board case and also not talking about type C case.
So if you are actually doing on custom board, then it is wrong.
Or if you cannot tell the difference between type C usb and micro usb, then it could be wrong too.
Also, please do not “grep usb”. Just show the full log. It should just be few lines after you connect the micro usb cable. If there is totally no new log, then please try other cable.
Hello, I attached the micro USB port and got ttyUSB3, here is the output for it… What should I do next?
You should go back to check Dave’s comment if your have /dev/ttyUSB3 now.
He already told you what to check.
Yeah, That is exactly what I have done. Here is the output in txt file
log.txt (532 Bytes)
the log did not show anything. Did you power up your device?
You have to open the UART connection before booting the device, or log that happens before the UART connection will not be caught.
Hello, the device was in force recovery mode so it did not print anything. I switched it on normally and it printed out something as shown in the txt file below. I am not sure about the localhost login and password. I tried the login and password for my host computer but it did not work. What else can I try?
log.txt (16.7 KB)
looks like your device booted up correctly, but the issues is that the user account was pre-configured before flashing. Did you do this on your own, or was this BSP taken from other people? We do not enable default users by default.
Run this command under Linux_for_Tegra and flash again:
sudo ./tools/l4t_create_default_user.sh -u “username” -p “password”
These are are the logs during installation from the UART port. I tried logging in using the username and password set above but it did not work.I noticed there was an option for autologin in the .sh file. What effect will there be if that option is enabled?
logs.txt (62.5 KB)
