Hey there,
how come that when I create a viewport, attach the camera, set the texture rendering (either LD 640x480 or 1920x1080) my vertical fov gets scaled in very strange ways???
This happens if I set the active camera before or after setting the textures.
Reproduced in Isaac2021.2.1, not sure if present on the newest one.
I ended up saving my apertures + rendering a couple of times + setting them back, but this is unexpected and very strange.
This is the snipped I use *already adapted for 2022
viewport_name = "Viewport"
viewport_handle = omni.kit.viewport_legacy.get_viewport_interface().get_instance(viewport_name)
if not viewport_handle:
viewport_handle = omni.kit.viewport_legacy.get_viewport_interface().create_instance()
viewport_name = omni.kit.viewport_legacy.get_viewport_interface().get_viewport_window_name(viewport_handle)
viewport_window = omni.kit.viewport_legacy.get_viewport_interface().get_viewport_window(viewport_handle)
viewport_window.set_texture_resolution(resolution[0], resolution[1])
if not is_headless:
viewport_window.set_window_pos(1000, 400)
viewport_window.set_window_size(300, 300)
viewport_window.set_active_camera(camera_path)
return viewport_window, viewport_name
