CREO 10 OMNIVERSE CONNECTOR crashing
PTC CREO 10 OMNIVERSE CONNECTOR while trying to export even a simple cube Creo is crashing. Can someone confirm that the Connector for Creo 10 is actually working?
You are trying to export a usd file ? You are using version 201.0.0 ? Can you try without materials ? Can you try not using Nucleus as the file location ?
Please provide more details. Yes it is working as normal.
Hi Richard, thanks for checking in. I’ve looked into the connector log files and found the follwing error message:
[Error] [omni.connect.ptccreo] Could not ascertain model unit system: “ballard”. Defaulting to cm.
I’ve convert or set our custom company unit format “ballard” to e.g. mmKs.
And voila the export worked as intended.
Ah yeah. That is a good idea. We cannot support custom unit formats like that.
