Hello, dear support!
We use the cuda-repo-10-0-local-10.0.130-410.48 package in Ubuntu 18.04 with our software for pattern recognition.
Since yesterday, the package has ceased to be installed due to unmet dependencies, as a result of the study, it was discovered that the repository (http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/) was updated on 02/26/2019
Please respond to this signal.
In the meantime, I’m trying to find a solution.
Thanks a lot.
My installation procedure of nvidia driver and cuda:
rm /etc/apt/sources.list.d/cuda*
apt remove nvidia-cuda-toolkit
apt purge nvidia-* -yq
apt-key adv --fetch-keys http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64/7fa2af80.pub
echo "deb http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 /" > /etc/apt/sources.list.d/cuda.list
aptitude install nvidia-driver-410 nvidia-modprobe -yq
apt-mark hold nvidia-driver-410
wget -O cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48_1.0-1_amd64.deb https://developer.nvidia.com/compute/cuda/10.0/Prod/local_installers/cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48_1.0-1_amd64
dpkg -i cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48_1.0-1_amd64.deb
apt-key add /var/cuda-repo-10-0-local-10.0.130-410.48/7fa2af80.pub
aptitude update -y
aptitude install cuda -y
export PATH=/usr/local/cuda/bin${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
Installation Log with unmet dependencies
deb Index of /compute/cuda/repos/ubuntu1804/x86_64 /" > /etc/apt/sources.list.d/cuda.list
Selecting previously unselected package cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48.
(Reading database ... 200537 files and directories currently installed.)
Preparing to unpack cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48_1.0-1_amd64.deb ...
Unpacking cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48 (1.0-1) ...
Setting up cuda-repo-ubuntu1804-10-0-local-10.0.130-410.48 (1.0-1) ...
OK
Get: 1 file:/var/cuda-repo-10-0-local-10.0.130-410.48 InRelease
Ign file:/var/cuda-repo-10-0-local-10.0.130-410.48 InRelease
Get: 2 file:/var/cuda-repo-10-0-local-10.0.130-410.48 Release [574 B]
Get: 3 file:/var/cuda-repo-10-0-local-10.0.130-410.48 Release [574 B]
Get: 4 file:/var/cuda-repo-10-0-local-10.0.130-410.48 Release.gpg [833 B]
Get: 5 file:/var/cuda-repo-10-0-local-10.0.130-410.48 Release.gpg [833 B]
Hit http://ua.archive.ubuntu.com/ubuntu bionic InRelease
Get: 6 file:/var/cuda-repo-10-0-local-10.0.130-410.48 Packages [24.4 kB]
Hit http://ua.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit http://ua.archive.ubuntu.com/ubuntu bionic-backports InRelease
Ign http://ftp.fau.de/trinity/trinity-builddeps-r14.0.0/ubuntu bionic InRelease
Hit http://ftp.fau.de/trinity/trinity-builddeps-r14.0.0/ubuntu bionic Release
Hit http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu bionic InRelease
Ign http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 InRelease
Get: 7 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 Release
Fetched 88.7 kB in 1s (102 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
Reading extended state information...
Initializing package states...
Writing extended state information...
Building tag database...
The following NEW packages will be installed:
cuda cuda-10-1{a} cuda-command-line-tools-10-1{a} cuda-compiler-10-1{a} cuda-cudart-10-1{a} cuda-cudart-dev-10-1{a} cuda-cufft-10-1{a} cuda-cufft-dev-10-1{a} cuda-cuobjdump-10-1{a} cuda-cupti-10-1{a} cu
da-curand-10-1{a} cuda-curand-dev-10-1{a} cuda-cusolver-10-1{a} cuda-cusolver-dev-10-1{a} cuda-cusparse-10-1{a} cuda-cusparse-dev-10-1{a} cuda-demo-suite-10-1{a} cuda-documentation-10-1{a} cuda-driver-dev
-10-1{a} cuda-drivers{a} cuda-gdb-10-1{a} cuda-gpu-library-advisor-10-1{a} cuda-libraries-10-1{a} cuda-libraries-dev-10-1{a} cuda-license-10-1{a} cuda-memcheck-10-1{a} cuda-misc-headers-10-1{a} cuda-npp-1
0-1{a} cuda-npp-dev-10-1{a} cuda-nsight-10-1{a} cuda-nsight-compute-10-1{a} cuda-nsight-systems-10-1{a} cuda-nvcc-10-1{a} cuda-nvdisasm-10-1{a} cuda-nvgraph-10-1{a} cuda-nvgraph-dev-10-1{a} cuda-nvjpeg-10
-1{a} cuda-nvjpeg-dev-10-1{a} cuda-nvml-dev-10-1{a} cuda-nvprof-10-1{a} cuda-nvprune-10-1{a} cuda-nvrtc-10-1{a} cuda-nvrtc-dev-10-1{a} cuda-nvtx-10-1{a} cuda-nvvp-10-1{a} cuda-runtime-10-1{a} cuda-samples
-10-1{a} cuda-sanitizer-api-10-1{a} cuda-toolkit-10-1{a} cuda-tools-10-1{a} cuda-visual-tools-10-1{a} default-jre{a} default-jre-headless{a} freeglut3{a} freeglut3-dev{a} libcublas-dev{a} libcublas10{a} l
ibdrm-dev{a} libgl1-mesa-dev{a} libgles1{a} libglu1-mesa-dev{a} libglvnd-core-dev{a} libglvnd-dev{a} libnvidia-cfg1-418{ab} libnvidia-common-418{a} libnvidia-compute-418{ab} libnvidia-decode-418{ab} libnv
idia-encode-418{ab} libnvidia-fbc1-418{ab} libnvidia-gl-418{ab} libnvidia-ifr1-418{ab} libx11-xcb-dev{a} libxcb-dri2-0-dev{a} libxcb-dri3-dev{a} libxcb-glx0-dev{a} libxcb-present-dev{a} libxcb-randr0-dev{
a} libxcb-shape0-dev{a} libxcb-sync-dev{a} libxcb-xfixes0-dev{a} libxmu-dev{a} libxmu-headers{a} libxshmfence-dev{a} libxxf86vm-dev{a} mesa-common-dev{a} nvidia-compute-utils-418{ab} nvidia-dkms-418{ab} n
vidia-driver-418{a} nvidia-kernel-common-418{ab} nvidia-kernel-source-418{ab} nvidia-utils-418{ab} openjdk-11-jre{a} openjdk-11-jre-headless{a} x11proto-xf86vidmode-dev{a} xserver-xorg-video-nvidia-418{a}
0 packages upgraded, 95 newly installed, 0 to remove and 0 not upgraded.
Need to get 1640 MB of archives. After unpacking 4367 MB will be used.
The following packages have unmet dependencies:
libnvidia-compute-410 : Conflicts: libcuda-5.0-1 which is a virtual package, provided by:
- libnvidia-compute-415 (415.27-0ubuntu0~gpu18.04.2), but it is not going to be installed
- libnvidia-compute-410 (410.78-0ubuntu1~gpu18.04.2), but 410.79-0ubuntu1 is installed
- libnvidia-compute-396 (396.54-0ubuntu0~gpu18.04.1), but it is not going to be installed
- libnvidia-compute-390 (390.87-0ubuntu0~gpu18.04.2), but it is not going to be installed
- libcuda1-340 (340.107-0ubuntu0~gpu18.04.1), but it is not going to be installed
- libcuda1-304 (304.137-0ubuntu2), but it is not going to be installed
- libnvidia-compute-418 (418.39-0ubuntu1), but 418.39-0ubuntu1 is to be installed
- libnvidia-compute-410 (410.79-0ubuntu1), but 410.79-0ubuntu1 is installed
- libnvidia-compute-410 (410.72-0ubuntu1), but 410.79-0ubuntu1 is installed
- libnvidia-compute-410 (410.48-0ubuntu1), but 410.79-0ubuntu1 is installed
- libnvidia-compute-390 (390.77-0ubuntu0.18.04.2), but it is not going to be installed
- libcuda1-340 (340.107-0ubuntu0.18.04.2), but it is not going to be installed
- libnvidia-compute-390 (390.48-0ubuntu3), but it is not going to be installed
- libcuda1-340 (340.106-0ubuntu3), but it is not going to be installed
Conflicts: libcuda-5.5-1 which is a virtual package, provided by:
Conflicts: libcuda-6.0-1 which is a virtual package, provided by:
Conflicts: libcuda-6.5-1 which is a virtual package, provided by:
Conflicts: libcuda-7.0-1 which is a virtual package, provided by:
Conflicts: libcuda-7.5-1 which is a virtual package, provided by:
- libnvidia-compute-396 (...
Thanks a lot!
Dmitro Makhonko
