i currently use zorin os 17.2 and its missing the cuda and when i try to install it gives me a driver mismatch error driver i am using is 570.124.04 but the cuda driver is 570.124.06 is this a number error? my vid card is the gforce 1650 please advise…thanks
i solved the problem seems the secure boot was turned on so now the smi and gpu are now showing correctly
Related topics
Topic | Replies | Views | Activity | |
API mismatch after installing CUDA7.5 on Ubuntu14.04 | 1 | 731 | March 10, 2016 | |
CUDA broke, reinstalled with "cuda error system driver mismatch" now | 0 | 2843 | July 17, 2020 | |
Where can I get the Cuda Toolkit 12.2.0.x that doesn't have the 535.54.03 embedded? | 5 | 85 | February 12, 2025 | |
Cuda container's drivers compatibility fails - System has unsupported display driver / cuda driver combination | 0 | 29 | June 9, 2025 | |
The cuda driver can't find compatible device. | 4 | 5331 | June 25, 2013 | |
Cuda 1.0 and Ubuntu Hardy Cuda 1.0 does'n work on Ubuntu Hardy | 1 | 5126 | April 30, 2008 | |
Fedora 10 cuda enabled driver install API mismatch error after installing cuda enabled drivers on fe | 2 | 9758 | February 12, 2009 | |
Cuda drivers have unmet dependencies? | 1 | 92 | September 26, 2024 | |
GTX 1060 update driver failed: code 52: | 4 | 2966 | October 8, 2021 | |
Installing Cuda on Ubuntu 22.04 with RTX 4090 | 4 | 24160 | November 17, 2022 |
