I’ve tried to install CUDA 5.5 Toolkit, but there was fault with Nsight Visual Studio Edition 3.1 during the installation. Also CUDA Samples didn’t install.
External Image
OS: Windows 8.1 Professional x64
GPU: GeForce GTS 450
IDE: Visual Studio 2012 Professional
adamce
April 13, 2014, 6:57pm
2
maybe you can find out something when calling the setup like that:
lzma extraction is done automatically when just clicking the downloaded file (maybe you need to select a different directory).
in the log file, just search for “error:” (including “:”).
found in here:
I had 5.5 installed, but uninstalled to check on an error. Now when I try to reinstall, it fails, and the only error I can briefly see is something about “Visual Studio 2008 settings”. Is there an error log generated somewhere? It correctly...
hope it helps : )
