I have the following setup:
GPU: Geforce GTX 1060 with Max-Q design, 6GB
GPU driver version: 398.36
Windows 10 version 17134.472 Built
When I type nvidia-smi in the CMD I see the GPU with all the needed details. as I try to install CUDA the problem starts, the installation doesn’t recognize the hardware and warning is popped up.
When I try to install the newest drivers of NVIDIA I also get a warning.
Can someone help me please?
Thank you for responding.
Should I download and install all the patches? or just the newest one?
You have to start with the base installer. A patch doesn’t provide the base installer functionality. After you have installed the base installer, install each of the patches.
I still didn’t manage to install the CUDA toolkit. I have uninstalled all the drivers were installed.
As I manually searched the appropriate drive at this link https://www.nvidia.com/drivers the suitable driver is 417.35. What should I do?
You don’t appear to be following the instructions I gave you.
I want to start from the beginning. what should I do know?
