GTX 1060 for cuda 9
Hi
I am using cuda GTX 1060 on windows 10.
Now I want to try the tensorflow with GPU support.
I checked the documentation on tensorflow and it’s been said they only support for cuda 9.0 or 8.0
But I found that I am using the driver 417.22, which only support for cuda 10(i tried more than once to download cuda 9 but fail to install).
It seems like the online driver search can only find the 4xx version, which i think all support the cuda 10 instead of 9.
So where can i find the right version of the driver and please give offer a link
THX
You can use driver 417.22 with CUDA 9.0 or CUDA 8.0
Newer drivers are backwards-compatible with older toolkits.
But the cude 9 is always fail to install. I tried at least 4 times,
any help?
There’s not much I can do with “always fail to install”, except point you at the instructions:
[url]Installation Guide Windows :: CUDA Toolkit Documentation
There are many many topics on this forum dealing with problems getting CUDA installer to work on Windows. You can search for them.
Here is one:
[url]https://devtalk.nvidia.com/default/topic/1033111/cuda-setup-and-installation/cuda-9-1-cannot-install-due-to-failed-visual-studio-integration/[/url]
If you follow the instructions in post #8 there, it should work.
Thx, this is what i need, seems like it’s VS’s problem
