CUDA 9.2 install failure (clean Centos 7) with GTX 1070 Ti
Any insight would be much appreciated.
Following instructions from a previous topic (https://devtalk.nvidia.com/default/topic/1035514/cuda-with-quot-geforce-gtx-1070-ti-quot-/#5260421) for install. Specifically, install driver first (using these instructions, http://www.advancedclustering.com/act_kb/installing-nvidia-drivers-rhel-centos-7/ ), then runfile installation according to the installation guide without installing driver.
Potentially relevant info here:
[i][jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
[jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 390.59 Wed May 9 22:33:42 PDT 2018
GCC version: gcc version 4.8.5 20150623 (Red Hat 4.8.5-28) (GCC)
[jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ uname -m && cat /etc/*release
x86_64
CentOS Linux release 7.5.1804 (Core)
NAME=“CentOS Linux”
VERSION=“7 (Core)”
ID=“centos”
ID_LIKE=“rhel fedora”
VERSION_ID=“7”
PRETTY_NAME=“CentOS Linux 7 (Core)”
ANSI_COLOR=“0;31”
CPE_NAME=“cpe:/o:centos:centos:7”
HOME_URL=“https://www.centos.org/
BUG_REPORT_URL=“https://bugs.centos.org/
CENTOS_MANTISBT_PROJECT=“CentOS-7”
CENTOS_MANTISBT_PROJECT_VERSION=“7”
REDHAT_SUPPORT_PRODUCT=“centos”
REDHAT_SUPPORT_PRODUCT_VERSION=“7”
[jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ uname -r
3.10.0-862.2.3.el7.x86_64[/i]
[jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ echo $PATH
/usr/local/cuda-9.2/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/jrasmussen/.local/bin:/home/jrasmussen/bin
[jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ echo $LD_LIBRARY_PATH
/usr/local/cuda-9.2/lib64
Here is my output from deviceQuery
[i][jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ bin/x86_64/linux/release/deviceQuery
bin/x86_64/linux/release/deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
→ CUDA driver version is insufficient for CUDA runtime version
Result = FAIL[/i]
Here is my output from the Samples make (note this was preceded by 7.3.1. Install Third-party Libraries because of the libGL error I received on a prior install attempt):
[i][jrasmussen@DESKTOP-UF08KE4 NVIDIA_CUDA-9.2_Samples]$ make
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleCooperativeGroups' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleCooperativeGroups.o -c simpleCooperativeGroups.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleCooperativeGroups simpleCooperativeGroups.o mkdir -p ../../bin/x86_64/linux/release cp simpleCooperativeGroups ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleCooperativeGroups’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/fp16ScalarProduct' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o fp16ScalarProduct.o -c fp16ScalarProduct.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o fp16ScalarProduct fp16ScalarProduct.o mkdir -p ../../bin/x86_64/linux/release cp fp16ScalarProduct ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/fp16ScalarProduct’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleSurfaceWrite' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleSurfaceWrite.o -c simpleSurfaceWrite.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleSurfaceWrite simpleSurfaceWrite.o mkdir -p ../../bin/x86_64/linux/release cp simpleSurfaceWrite ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleSurfaceWrite’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cdpSimpleQuicksort' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -dc -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cdpSimpleQuicksort.o -c cdpSimpleQuicksort.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cdpSimpleQuicksort cdpSimpleQuicksort.o -lcudadevrt mkdir -p ../../bin/x86_64/linux/release cp cdpSimpleQuicksort ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cdpSimpleQuicksort’
make[1]: Entering directory `/home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleVoteIntrinsics’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleVoteIntrinsics.o -c simpleVoteIntrinsics.cu
simpleVote_kernel.cuh(58): warning: function “all”
/usr/local/cuda-9.2/bin/..//include/device_atomic_functions.hpp(216): here was declared deprecated (“__all() is not valid on compute_70 and above, and should be replaced with __all_sync().To continue using __all(), specify virtual architecture compute_60 when targeting sm_70 and above, for example, using the pair of compiler options: -arch=compute_60 -code=sm_70.”)
/usr/local/cuda-9.2/bin/..//include/device_atomic_functions.hpp(216): here was declared deprecated (“__all() is deprecated in favor of __all_sync() and may be removed in a future release (Use -Wno-deprecated-declarations to suppress this warning).”)
ptxas /tmp/tmpxft_0000105a_00000000-12_simpleVoteIntrinsics.compute_30.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-11_simpleVoteIntrinsics.compute_35.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-10_simpleVoteIntrinsics.compute_37.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-9_simpleVoteIntrinsics.compute_50.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-8_simpleVoteIntrinsics.compute_52.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-7_simpleVoteIntrinsics.compute_60.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-6_simpleVoteIntrinsics.compute_61.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
ptxas /tmp/tmpxft_0000105a_00000000-5_simpleVoteIntrinsics.compute_70.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ may produce unpredictable results on sm_70 and later architectures
ptxas /tmp/tmpxft_0000105a_00000000-5_simpleVoteIntrinsics.compute_70.ptx, line 108; warning : Instruction ‘vote’ without ‘.sync’ is deprecated since PTX ISA version 6.0 and will be discontinued in a future PTX ISA version
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleVoteIntrinsics simpleVoteIntrinsics.o
cp simpleVoteIntrinsics ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleVoteIntrinsics' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cdpSimplePrint’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -dc -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cdpSimplePrint.o -c cdpSimplePrint.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cdpSimplePrint cdpSimplePrint.o -lcudadevrt
cp cdpSimplePrint ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cdpSimplePrint' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMulCUBLAS’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o matrixMulCUBLAS.o -c matrixMulCUBLAS.cpp
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o matrixMulCUBLAS matrixMulCUBLAS.o -lcublas
cp matrixMulCUBLAS ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMulCUBLAS' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleZeroCopy’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleZeroCopy.o -c simpleZeroCopy.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleZeroCopy simpleZeroCopy.o
cp simpleZeroCopy ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleZeroCopy' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleAssert’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleAssert.o -c simpleAssert.cu
simpleAssert.cu(71): warning: variable “devID” was set but never used
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleAssert simpleAssert.o
cp simpleAssert ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleAssert' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleLayeredTexture’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleLayeredTexture.o -c simpleLayeredTexture.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleLayeredTexture simpleLayeredTexture.o
cp simpleLayeredTexture ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleLayeredTexture' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMulDrv’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o matrixMulDrv.o -c matrixMulDrv.cpp
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=compute_30 -o matrixMulDrv matrixMulDrv.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda
cp matrixMulDrv ../../bin/x86_64/linux/release
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o matrixMul_kernel64.ptx -ptx matrixMul_kernel.cu
mkdir -p data
cp -f matrixMul_kernel64.ptx ./data
cp -f matrixMul_kernel64.ptx ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMulDrv' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleCallback’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o multithreading.o -c multithreading.cpp
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleCallback.o -c simpleCallback.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleCallback multithreading.o simpleCallback.o
cp simpleCallback ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleCallback' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAdd_nvrtc’
g++ -I../../common/inc -I"/usr/local/cuda-9.2"/include -o vectorAdd.o -c vectorAdd.cpp
g++ -o vectorAdd_nvrtc vectorAdd.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda -lnvrtc
cp vectorAdd_nvrtc ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAdd_nvrtc' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleOccupancy’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleOccupancy.o -c simpleOccupancy.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleOccupancy simpleOccupancy.o
cp simpleOccupancy ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleOccupancy' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/systemWideAtomics’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o systemWideAtomics.o -c systemWideAtomics.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o systemWideAtomics systemWideAtomics.o
cp systemWideAtomics ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/systemWideAtomics' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleSeparateCompilation’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -dc -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleDeviceLibrary.o -c simpleDeviceLibrary.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -lib -o simpleDeviceLibrary.a simpleDeviceLibrary.o
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -dc -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleSeparateCompilation.o -c simpleSeparateCompilation.cu
simpleSeparateCompilation.cu(90): warning: variable “devID” was set but never used
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleSeparateCompilation simpleDeviceLibrary.a simpleSeparateCompilation.o
cp simpleSeparateCompilation ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleSeparateCompilation' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simplePitchLinearTexture’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simplePitchLinearTexture.o -c simplePitchLinearTexture.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simplePitchLinearTexture simplePitchLinearTexture.o
cp simplePitchLinearTexture ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simplePitchLinearTexture' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/inlinePTX’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o inlinePTX.o -c inlinePTX.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o inlinePTX inlinePTX.o
cp inlinePTX ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/inlinePTX' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAdd’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o vectorAdd.o -c vectorAdd.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o vectorAdd vectorAdd.o
cp vectorAdd ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAdd' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cppOverload’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cppOverload.o -c cppOverload.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cppOverload cppOverload.o
cp cppOverload ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cppOverload' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTextureDrv’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o simpleTextureDrv.o -c simpleTextureDrv.cpp
simpleTextureDrv.cpp: In function ‘int getMaxGflopsDeviceId()’:
simpleTextureDrv.cpp:151:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations]
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device));
simpleTextureDrv.cpp:74:50: note: in definition of macro ‘checkCudaErrors’
define checkCudaErrors(err) __checkCudaErrors (err, FILE, LINE)
simpleTextureDrv.cpp:151:81: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations]
simpleTextureDrv.cpp:172:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations]
simpleTextureDrv.cpp:172:81: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations]
simpleTextureDrv.cpp: In function ‘void runTest(int, char**)’:
simpleTextureDrv.cpp:354:21: warning: ‘CUresult cuParamSetTexRef(CUfunction, int, CUtexref)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:10130) [-Wdeprecated-declarations]
checkCudaErrors(cuParamSetTexRef(transform, CU_PARAM_TR_DEFAULT, cu_texref));
simpleTextureDrv.cpp:354:79: warning: ‘CUresult cuParamSetTexRef(CUfunction, int, CUtexref)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:10130) [-Wdeprecated-declarations]
simpleTextureDrv.cpp: In function ‘CUresult initCUDA(int, char**, CUfunc_st**)’:
simpleTextureDrv.cpp:529:21: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations]
checkCudaErrors(cuDeviceComputeCapability(&major, &minor, cuDevice));
simpleTextureDrv.cpp:529:71: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations]
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=compute_30 -o simpleTextureDrv simpleTextureDrv.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda
cp simpleTextureDrv ../../bin/x86_64/linux/release
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o simpleTexture_kernel64.ptx -ptx simpleTexture_kernel.cu
mkdir -p data
cp -f simpleTexture_kernel64.ptx ./data
cp -f simpleTexture_kernel64.ptx ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTextureDrv' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cudaTensorCoreGemm’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -maxrregcount=255 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cudaTensorCoreGemm.o -c cudaTensorCoreGemm.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cudaTensorCoreGemm cudaTensorCoreGemm.o
cp cudaTensorCoreGemm ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cudaTensorCoreGemm' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simplePrintf’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simplePrintf.o -c simplePrintf.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simplePrintf simplePrintf.o
cp simplePrintf ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simplePrintf' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTemplates_nvrtc’
g++ -I../../common/inc -I"/usr/local/cuda-9.2"/include -o simpleTemplates.o -c simpleTemplates.cpp
g++ -o simpleTemplates_nvrtc simpleTemplates.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda -lnvrtc
cp simpleTemplates_nvrtc ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTemplates_nvrtc' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleCubemapTexture’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleCubemapTexture.o -c simpleCubemapTexture.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleCubemapTexture simpleCubemapTexture.o
cp simpleCubemapTexture ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleCubemapTexture' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/clock’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o clock.o -c clock.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o clock clock.o
cp clock ../../bin/x86_64/linux/release
make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/clock' make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTexture’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleTexture.o -c simpleTexture.cu
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleTexture simpleTexture.o
cp simpleTexture ../../bin/x86_64/linux/release
make[1]: Leaving directory `/home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTexture’
WARNING - No MPI compiler found.
CUDA Sample “simpleMPI” cannot be built without an MPI Compiler.
This will be a dry-run of the Makefile.
For more information on how to set up your environment to build and run this
sample, please refer the CUDA Samples documentation and release notes
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleMPI' [@] mpicxx -I../../common/inc -o simpleMPI_mpi.o -c simpleMPI.cpp [@] /usr/local/cuda-9.2/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleMPI.o -c simpleMPI.cu [@] mpicxx -o simpleMPI simpleMPI_mpi.o simpleMPI.o -L/usr/local/cuda-9.2/lib64 -lcudart [@] mkdir -p ../../bin/x86_64/linux/release [@] cp simpleMPI ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleMPI’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleMultiCopy' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleMultiCopy.o -c simpleMultiCopy.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleMultiCopy simpleMultiCopy.o mkdir -p ../../bin/x86_64/linux/release cp simpleMultiCopy ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleMultiCopy’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cudaOpenMP' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -Xcompiler -fopenmp -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cudaOpenMP.o -c cudaOpenMP.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cudaOpenMP cudaOpenMP.o -lgomp mkdir -p ../../bin/x86_64/linux/release cp cudaOpenMP ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cudaOpenMP’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/asyncAPI' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o asyncAPI.o -c asyncAPI.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o asyncAPI asyncAPI.o mkdir -p ../../bin/x86_64/linux/release cp asyncAPI ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/asyncAPI’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleAtomicIntrinsics' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleAtomicIntrinsics.o -c simpleAtomicIntrinsics.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleAtomicIntrinsics_cpu.o -c simpleAtomicIntrinsics_cpu.cpp "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleAtomicIntrinsics simpleAtomicIntrinsics.o simpleAtomicIntrinsics_cpu.o mkdir -p ../../bin/x86_64/linux/release cp simpleAtomicIntrinsics ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleAtomicIntrinsics’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/clock_nvrtc' g++ -I../../common/inc -I"/usr/local/cuda-9.2"/include -o clock.o -c clock.cpp g++ -o clock_nvrtc clock.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda -lnvrtc mkdir -p ../../bin/x86_64/linux/release cp clock_nvrtc ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/clock_nvrtc’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAddDrv' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o vectorAddDrv.o -c vectorAddDrv.cpp vectorAddDrv.cpp: In function ‘int getMaxGflopsDeviceId()’: vectorAddDrv.cpp:144:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations] checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device)); ^ vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’ #define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__) ^ vectorAddDrv.cpp:144:81: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations] checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device)); ^ vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’ #define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__) ^ vectorAddDrv.cpp:165:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations] checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device)); ^ vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’ #define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__) ^ vectorAddDrv.cpp:165:81: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations] checkCudaErrors(cuDeviceComputeCapability(&major, &minor, current_device)); ^ vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’ #define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__) ^ vectorAddDrv.cpp: In function ‘int main(int, char**)’: vectorAddDrv.cpp:323:25: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations] checkCudaErrors(cuDeviceComputeCapability(&major, &minor, devID)); ^ vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’ #define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__) ^ vectorAddDrv.cpp:323:72: warning: ‘CUresult cuDeviceComputeCapability(int*, int*, CUdevice)’ is deprecated (declared at /usr/local/cuda-9.2/bin/..//include/cuda.h:2528) [-Wdeprecated-declarations] checkCudaErrors(cuDeviceComputeCapability(&major, &minor, devID)); ^ vectorAddDrv.cpp:71:50: note: in definition of macro ‘checkCudaErrors’ #define checkCudaErrors(err) __checkCudaErrors (err, __FILE__, __LINE__) ^ "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=compute_30 -o vectorAddDrv vectorAddDrv.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda mkdir -p ../../bin/x86_64/linux/release cp vectorAddDrv ../../bin/x86_64/linux/release "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=compute_30 -o vectorAdd_kernel64.ptx -ptx vectorAdd_kernel.cu mkdir -p data cp -f vectorAdd_kernel64.ptx ./data mkdir -p ../../bin/x86_64/linux/release cp -f vectorAdd_kernel64.ptx ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/vectorAddDrv’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleAtomicIntrinsics_nvrtc' g++ -I../../common/inc -I"/usr/local/cuda-9.2"/include -o simpleAtomicIntrinsics.o -c simpleAtomicIntrinsics.cpp g++ -I../../common/inc -I"/usr/local/cuda-9.2"/include -o simpleAtomicIntrinsics_cpu.o -c simpleAtomicIntrinsics_cpu.cpp g++ -o simpleAtomicIntrinsics_nvrtc simpleAtomicIntrinsics.o simpleAtomicIntrinsics_cpu.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda -lnvrtc mkdir -p ../../bin/x86_64/linux/release cp simpleAtomicIntrinsics_nvrtc ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleAtomicIntrinsics_nvrtc’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMul' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o matrixMul.o -c matrixMul.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o matrixMul matrixMul.o mkdir -p ../../bin/x86_64/linux/release cp matrixMul ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMul’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTemplates' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleTemplates.o -c simpleTemplates.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleTemplates simpleTemplates.o mkdir -p ../../bin/x86_64/linux/release cp simpleTemplates ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleTemplates’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleIPC' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleIPC.o -c simpleIPC.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleIPC simpleIPC.o mkdir -p ../../bin/x86_64/linux/release cp simpleIPC ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleIPC’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleP2P' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleP2P.o -c simpleP2P.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleP2P simpleP2P.o mkdir -p ../../bin/x86_64/linux/release cp simpleP2P ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleP2P’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleMultiGPU' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleMultiGPU.o -c simpleMultiGPU.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleMultiGPU simpleMultiGPU.o mkdir -p ../../bin/x86_64/linux/release cp simpleMultiGPU ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleMultiGPU’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMul_nvrtc' g++ -I../../common/inc -I"/usr/local/cuda-9.2"/include -o matrixMul.o -c matrixMul.cpp g++ -o matrixMul_nvrtc matrixMul.o -L/usr/local/cuda-9.2/lib64/stubs -lcuda -lnvrtc mkdir -p ../../bin/x86_64/linux/release cp matrixMul_nvrtc ../../bin/x86_64/linux/release cp ""/usr/local/cuda-9.2"/include/cooperative_groups.h" . cp ""/usr/local/cuda-9.2"/include/cooperative_groups_helpers.h" . make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/matrixMul_nvrtc’
make[1]: Entering directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cppIntegration' "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cppIntegration.o -c cppIntegration.cu "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cppIntegration_gold.o -c cppIntegration_gold.cpp "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o main.o -c main.cpp "/usr/local/cuda-9.2"/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o cppIntegration cppIntegration.o cppIntegration_gold.o main.o mkdir -p ../../bin/x86_64/linux/release cp cppIntegration ../../bin/x86_64/linux/release make[1]: Leaving directory /home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/cppIntegration’
make[1]: Entering directory `/home/jrasmussen/Downloads/NVIDIA_CUDA-9.2_Samples/0_Simple/simpleStreams’
“/usr/local/cuda-9.2”/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_37,code=sm_37 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_52,code=sm_52 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_61,code=sm_61 -gencode arch=compute_70,code=sm_70 -gencode arch=compute_70,code=compute_70 -o simpleStreams.o -c simpleStreams.cu
