I have already setup cuda on my arm device ( Tegra K1 ). I am trying to install cuda cross compile on my host machine running ubuntu 14.04. I have added the foreign architecture and downloaded .deb file as well. Now when I try to install cross compile i get following message
ubuntu@ubuntu:/usr$ sudo apt-get install cuda-cross-armhf-6-5
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-cross-armhf-6-5 : Depends: cuda-toolkit-6-5 (= 6.5-19) but it is not going to be installed
Depends: g+±arm-linux-gnueabihf but it is not installable
E: Unable to correct problems, you have held broken packages.
ubuntu@ubuntu:/usr$ sudo apt-get install cuda-toolkit-6-5
cuda-toolkit-6-5 : Depends: cuda-core-6-5 (= 6.5-19) but it is not going to be installed
Depends: cuda-command-line-tools-6-5 (= 6.5-19) but it is not going to be installed
Depends: cuda-samples-6-5 (= 6.5-19) but it is not going to be installed
Depends: cuda-documentation-6-5 (= 6.5-19) but it is not going to be installed
Depends: cuda-visual-tools-6-5 (= 6.5-19) but it is not going to be installed
I am new to both ubuntu and cuda. Please guide me with the installation.
