I’m on a 2013 macbook rpo
running cuda driver version 418.163 - the latest
Right next to it is a message prompting me with “update required”.
can’t find anything else to update it too. Any advice?
Same issue…prompting me to update
I´m on a MacBook Pro (Retina, 15 inches, early 2014)
NVIDIA GeForce GT 750M 2048 MB
macos high sierra 10.13.6 (17G9016)
CUDA Driver Version: 418.163
GPU Driver Version: 355.11.10.10.40.102
nvidia web driver 387.10.10.10.40.132
formated my hard drive, erase cuda and web driver but nothing helps
Likewise for my machine.
CUDA Driver Version: 418.163 Update Required …but there is no update.
Installed the latest update I could find. CUDA preferences appears after every restart with the message “No newer CUDA Driver available” but also “Update Required” in red. The information button opens a popup:
"The CUDA Driver currently installed on your system needs to be updated. Please update to the latest CUDA Driver to ensure your CUDA-enabled applications continue to function properly.’
The button “Install CUDA Update” is greyed out.
The button “CUDA Driver Info & Updates” looks clickable but does nothing at all.
macOS Mojave
Version 10.14.6
iMac (27-inch, Late 2013)
Processor 3.4 GHz Intel Core i5
Graphics NVIDIA GeForce GTX 780M 4 GB
“Apple’s recently released macOS 10.14 (Mojave) does not support CUDA.” See https://devtalk.nvidia.com/default/topic/1042279/cuda-setup-and-installation/cuda-10-and-macos-10-14/
deleted
deleted
As Movjave Doesn’t Support Cuda. If you still have a verson of High Serria then you can downgrade back.
I have a GPU driver of 355.11.10.10.40.102
Cuda driver of 418.163
The Gpu driver is grayed out though, was wondering if it would be a problem
As Cuda has a required update but i can install the update for it.
Would CPU driver grayed out be that problem?
Having Same Problems as Mkstix6, but Im still on High Serria
