I’m trying to use the cuda profiler, but I get the following error:
Program run #1 was aborted after maximum program execution time duration of 360 seconds.
Error -94 in reading profiler output.
Minimum expected columns (method,gputime,cputime,occupancy) not found in profiler output file.
I’m profiling the sample matrix multiplication of cuda with maximum execution time of 2000 sec. The kernel exits successfully but I get the same error … how much time it is usually required?
