CUDA Profiler Error
Hi all,
I get the following error when I try to use cuda profiler to monitor my project.
The problem is I don’t get this error when I use the profiler on one of the existing nvidia sample projects.
My projects executes completely with no errors. But, I have no clue what I’m doing wrong here. Any suggestions???
Below is the error I get:
=== Start profiling for session ‘Session2’ ===
Start program xterm -e /home/maryam/NVIDIA_CUDA_SDK/bin/linux/release/denoising, run #1 …
Program run #1 completed.
Error -97 in reading profiler output.
Unable to open file.
Are you seeing this with the Visual Profiler? If so, are you using the latest release:
[url=“http://forums.nvidia.com/index.php?showtopic=65489”]http://forums.nvidia.com/index.php?showtopic=65489[/url]
The best way to identify the root cause is to run the application with profiling enabled from the command line.
Sorry for barging in here, I believe I have a similar problem.
I’m using the driver API, I have compiled my kernels using -pg. I have the following environment variables set:
export CUDA_PROFILE='1'
export CUDA_PROFILE_CONFIG='temp_cuda_profiler.conf'
export CUDA_PROFILE_CSV='1'
export CUDA_PROFILE_LOG='temp_cuda_profiler_0.csv'
temp_cuda_profiler.conf contains
gld_incoherent
gld_coherent
gst_incoherent
gst_coherent
(I just tried to copy what the visual profiler is doing, hope I caught everything)
After I do all that and run my program, temp_cuda_profiler_0.csv gets created, but is empty.
For reference, if I unset everything but CUDA_PROFILE, I get a file cuda_profile.log with this here:
method,gputime,cputime,occupancy
method=[ fill ] gputime=[ 4.992 ] cputime=[ 12.000 ] occupancy=[ 0.333 ]
method=[ fill ] gputime=[ 3.008 ] cputime=[ 5.000 ] occupancy=[ 0.333 ]
method=[ fill ] gputime=[ 2.944 ] cputime=[ 8.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 6.048 ] cputime=[ 8.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 6.048 ] cputime=[ 7.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 5.984 ] cputime=[ 8.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 6.112 ] cputime=[ 7.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 5.856 ] cputime=[ 8.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 6.272 ] cputime=[ 7.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 6.016 ] cputime=[ 8.000 ] occupancy=[ 0.333 ]
method=[ axpbyz ] gputime=[ 5.888 ] cputime=[ 7.000 ] occupancy=[ 0.333 ]
etc etc
CUDA2beta, Linux x86-64, Driver 174.55, Ubuntu 8.04, Linux 2.6.24-17
What am I missing?
Andreas
The solution is simple: Detailed profiling does not work on a Quadro FX570, it’s fine on other cards.
Andreas
