Error -94 in reading profiler output.
I have a problem with CUDA profiler.
Here is the output
=== Start profiling for session ‘Session1’ ===
Start program ‘C:/Documents and Settings/All Users/Application Data/NVIDIA Corporation/NVIDIA CUDA SDK/projects/WY_ESAW_texturemem_nosmem/Release/ESAW.exe’ run #1 …
Program run #1 completed.
Start program ‘C:/Documents and Settings/All Users/Application Data/NVIDIA Corporation/NVIDIA CUDA SDK/projects/WY_ESAW_texturemem_nosmem/Release/ESAW.exe’ run #2 …
Program run #2 completed.
Start program ‘C:/Documents and Settings/All Users/Application Data/NVIDIA Corporation/NVIDIA CUDA SDK/projects/WY_ESAW_texturemem_nosmem/Release/ESAW.exe’ run #3 …
Program run #3 completed.
Minimum expected columns (method,gputime,cputime,occupancy) not found in profiler output file.
The program runs well in command line, and does not need to press key to end the program.
I did not have this problem before, but when updagraing CUDA SDK from 1.0 to 2.1, I cannot profile successfully.
Thanks for any suggestions.
I also tried newer version of cuda profiler tool v1.0, still the same error…
fixed now…
Should use profiler 1.1, did not notice that at the download page
sorry for that.
