After reading through various posts on this forum, google and of course the release notes I’d tracked this message:
“Unable to load cuda library. CUDA Visual Profiler device features will be disabled.”
Down to one of two things:
CUDA library was not being load from the LD_library_path
cudaprof is not recognising my system properly
I’m happy that I’ve ruled out point 1 by setting the LD_library_path numerous times and being able to see that cudaprof can see this in its environment settings. So that leaves point 2!
Running ./deviceQuery from the SDK gives:
[codebox]There are 2 devices supporting CUDA
Device 0: “GeForce 9800M GTX”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 1073020928 bytes
Number of multiprocessors: 14
Number of cores: 112
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.55 GHz
Concurrent copy and execution: Yes
Device 1: “GeForce 9800M GTX”
Total amount of global memory: 1073479680 bytes
Warp size: 32
Test PASSED
Press ENTER to exit…
[/codebox]
So I know that I was able to compile and run CUDA test SDKs and they can determine my devices but why won’t the CUDA visual profiler?
I’m running Fedora 10 x86_64 with what I think are the latest beta drivers: 185.19 (hmmmm looks like there is now 185.18.04 which is newer… will test)
Can anyone point me in the right direction?
