Cumulus Linux LACP modes
Hi community,
In Onyx, when I configure LACP, I have to set it to on, active or passive mode:
interface ethernet x/x mlag-channel-group y mode [active, passive, on]
While in Cumulus Linux, when you configure LACP, you cannot configure this setting. The documentation only says:
"Cumulus Linux supports IEEE 802.3ad link aggregation mode (802.3ad) and balance-xor mode. The default mode is 802.3ad."
Any idea?
Regards,
Julián
What would you like to configure? A dynamic (LACP) or static bond?
Hi attilla,
I am going to convert my Onyx switch into Cumulus Linux. My LACP configuration I have in Onyx is like this:
interface ethernet 1/1 mlag-channel-group 1 mode active
So I think it is dynamic bond.
Regards,
Julián
Then, what are the commands for configuring Active or Passive mode? Because I don’t find them in the Cumulus Linux User Guide.
Regards,
Julián
Cumulus refers to LACP passive mode as “LACP Bypass” → LACP Bypass | Cumulus Linux 5.10
I see LACP Bypass doesn’t mean LACP Passive. “In Cumulus Linux, LACP bypass allows a bond configured in 802.3ad mode to become active and forward traffic even when there is no LACP partner.”
Regards,
Julian
